gvincent
Everything posted by gvincent
  1. Do you have a bulb for the SES light? (Service engine soon or CEL) Have you checked the VATS was really removed, do you have the Fuel pump wiring correct with the PCM? Check the injectors with NOID indicator I believe they need a negative voltage to trigger. Just tossing around a few ideas Some of these kept me from running when I was trying to start it 5 years ago? Do you have a laptop and TunerCAT?, sometimes the VATS programmed out works just fine but others have had to also put a resistor inline that was the same value as the ignition key resistor chip
  2. Haven't heard from Mdantonio in quite some time, This was tossed around a bit at the ZCON convention here in New Hampshire last August with a Scarab owner from Virginia, myself and a few other V8 conversions from also MA and NY, we all would love to put together a registry and have emblems available for the registered owners. I hope this moves forward I thought it was a great Idea.
  3. For what it is worth I have a 7/8" Tilton master on my LT1, stock 95 Firebird clutch and pressure plate and clutch kit made by Fort Worth, had the stock flywheel re-surfaced and run a Metal T5 slave cylinder from Tremec for a 93 F body from AutoZone, been running fine for 5 years now...
  4. Bringing up a 3 year old thread here hoping there has been some updates on lighting since then. Well I just read this whole thread and was all ready to go ahead and cobble an HID headlight together from an H4 housing until I read the last post. Went to the HIDplanet website ( www.hidplanet.com) and got totally lost. I just want to upgrade those dim 280Z headlights so I can drive at night and wanted to go the brightest and see the furthest distance possible, especially since I have the smoked headlight covers.
  5. Been running my custom Jones 40" 2.5" ID X 4" OD glass pack pipes for 5 years now with no issues. Fairly quiet just soft pedal cruising or putting by a police car but fairly loud with the throttle punched hard.
  6. Would love to see some original Scarab emblems and lettering done...
  7. You can swap the oil pan out in the car, it is not easy but can be done. Be careful with the front and rear seals not moving, especially the rear. Be sure to check the oil pick-up tube and the new pan clearance. do a dry fit with silly putty or something similar to check pick up tube clearance not being too little or too much. I think the 7 quart TransDap Hamburger pan and pick-up tube with the high volume Mellings pump might of had something to do with my rod bearing failure but I haven't removed the pan on that engine yet to verify I will eventually finish the other LT1 and use the Hamburger pan again. I still don't understand how your engine sits so low when my LT1 is slightly higher than the crossmember. I'll jack it up and take some pics maybe this weekend.
  8. I think Mcleod might have a flywheel that uses all the LT1 pressure plates and flywheels. I did a post on this years ago when I was considering a 400SBC mated to the LT1 T56 It may still be posted, search, I used a 7/8" Tilton master that bolted right in (Save the shaft/adaptor from your stock master) and a Metal T5 slave from AutoZone (Late 80's Camaro) with -3AN braided hose and the GM Quik-connect to -3AN adaptor at the slave. (Russel 640281) There is a bleeder on the slave. This is also posted here somewhere
  9. Godspeed Ross, You touched so many lives here in the Z community, always helping out, we have lost a very special person and will be truly missed....but always fondly remembered.
  10. With a first Gen SBC you need to move the hood latch anyway, JTR has a kit for this. you can mount a triangulated brace to the firewall a little further apart than mine is to clear the distributor, I have a piece on angle stock running between the two ends spreading it further apart rather than a single point.
  11. I am finally putting on a 30 year old IMSA GT 3 Piece Urethane version this week that I have had for since I first bought my 78 in 82, I never put it on and honestly had forgotten about it until recently. I should have it back from the body shop this weekend. I don't think you can find the Urethane ones anymore as they have a bit more detail on the sides that I haven't seen with the fiberglass ones.
  12. Can you show some pictures of the install and what year Isuzu Impulse? Thanks, Greg
  13. In that same thread on 280Z swap you will find some Recaro and Corbeau installs as well Also Here: http://forums.hybridz.org/topic/111592-corbeau-a4s-in-280z/ Although I was trying to keep the 280Z seats in one thread
  14. I used the Thunderbird fan, it is a one speed and the shroud fits the radiator opening pretty well, using a 4 row Griffin and a 180 thermostat with the computer to turn the fan on at 180, never goes over 190 even in traffic during the summer.
  15. Just in time for ZCON 2013 New England.....liking the BSR better, Get it autographed!
  16. Thanks Rich, do you have or can you get any pictures?
  17. Hey Mike, could we see some pictures and maybe post them on the 280Z seat swap list? http://forums.hybrid...seat-swap-list/
  18. I would love to see pictures and a write up on the Neon SRT4 seats in a 280Z, any specific year Neon?
  19. If you haven't found it yet in your search there is a 280Z seat swap list and there are some good pictures by Padam07 on his cutting out the 280Z Hump and welding in a new plate. Post #40 on page 2 and 104 on page 6 http://forums.hybridz.org/topic/88301-280z-seat-swap-list/page-2 I have been trying to track and get posted and document all seat swaps into the 280Z hump cars in this thread so all can use as a reference and maybe become a sticky some day. So if you could please post your write up and progress pics to this thread also. Thanks, Greg
  20. If you haven't found it yet there is a thread for the 280Z swap list I started years ago Here: http://forums.hybridz.org/topic/88301-280z-seat-swap-list/page-2 on Post #40 Page 2 and #105 page 6 Padam07 has a good write up and some pics of cutting out the 280Z hump and welding in a new plate. Dudeboy and CrayZ please also post pictures in the 280Z swaet swap thread also on your progress. I have been trying to put everything concerning seats in the Humped 280Z in one place for everybody to find it easy for reference. Thanks, Greg
  21. I would be interested too. I'll add this info to the "280Z seat swap thread http://forums.hybridz.org/topic/88301-280z-seat-swap-list/
  22. Mark, I have another LT1 motor I want to build and stroke and would like to know what went into your LT1 build, it sounds pretty serious. Greg
