LLave
    5
Everything posted by LLave
  1. You will be doing rust repairs. My suggestion is do whole floor pans and bad dog rails. I wish I had. Doing it spot by spot took way longer and the result is not as good.
  2. That is amazing. You should rent it out. I would rent it.
  3. I bet you can trade it for an LT1 version. Put it up on LS1 Tech
  4. Great work! That is a tight fit. Those are going to work great for you. Much respect for the accomplishment. I think the take away with "custom" engine mounts is the buy a set of headers ahead of time, mock up with them and build around them. Haha. I wish I had too.
  5. Part of their storage burned to the ground. Not the whole shop.
  6. Good stuff right there. Team work makes the dream work.
  7. Hahah, didn't even see that. Wow. Late to the party.
  8. Good luck with your search. I finally got one off ebay. In my hunt last year, both Whitehead Performance and Arizona Z Car told me that they had plans to start manufacturing their own. You may check in with them.
  9. I ordered tubing with all the same radius for that project. You would have to swap out the center piece and clamp. The clamp could have been made adjustable I suppose. The center is sacrificial, I just made it out of poplar scrap glued together. The Swag portaband tables are another affordable option http://www.swagoffroad.com/SWAG-Portaband-Tables-Accessories_c_35.html
  10. Looking great. You will make so much power, regardless of how long or unequal the tubes are, I wouldn't even worry about it. I made a tube holding jig for my chop saw, nothing fancy, but functional. With a 14" metal cutting carbide blade, it worked pretty well. Once I switched to a nicer 90t steel demon blade, it cut really well. It is a little slower to tighten and loosen nut, but after almost cutting my thumb off, I decided it was worth it.
  11. Yeah, you can't leave those. Cut it out, repair anything inside, shoot with weld through, put new panel on. Good luck.
  12. Found a picture, not my car just a random from the internets.
  13. My car has those too. I am 90% sure they are to mount the horns.
  14. Just trim off the back end of that control arm.
  15. I used a VA Sanden 709, it was pretty compact. But like you said, you will run out of room fast. Everything wants to occupy the same space at the same time. Have you checked hood clearance with that alt bracket? Probably ok, but looks like it might be close.
  16. Smaller alternator? What is the part number for the bracket you are using there? Can the bracket be configured so that the alternator is on the side of the valve cover, over by the header? If you are dead set on that location you could cut, notch and weld up that valve cover. A quick google shows me that many people have done that.
  17. What a great project. I am sure that at times it was difficult to keep. I am glad you did. That stereo is way cool in a retro way. I have never seen one like it. Might want to download this PDF http://www.oldsmobility.com/board/RM610.pdf
  18. Nice, that is the first I have seen this transmission. Keep us posted.
  19. That little swoop from the main rails to the rears, yeah I am stealing that. When my car goes back on the rotisserie I am going to add that.
  20. Holy hell... What a gear box.
  21. I think that is going to work out great. Quick google-foo shows me that Radium has an FPR housing built around that same regulator style. Makes for nice way to land AN fittings on that regulator. Is that what you are using? http://www.radiumauto.com/Fuel-Pressure-Regulator-P229.aspx I am considering ditching my Aeromotive regulator, seems like lots of people have problems with them.
