LLave
5
Everything posted by LLave
I did mine in very similar fashion. Keep in mind that the factory used fairly low temp solder to attach the hose barbs and sending unit flange. I got mine too hot and had some solder run out. Which was a bit of a pain to fix. I ended up fitting the Tanks inc sending unit in there as well. It was tight and I am not sure I gained much from it. In hindsight I should have just fixed the factory one. Do you plan on sealing the inside? I would be happy to share notes on that. I got good at it after I had to completely strip and re-do it a second time. Don't be like me, do it once.
I would find another chassis. I just heard a rumor from a coworker there is a clean shell down the road for $800. They are out there. I would way rather do floors than that roof repair.
Might try the colbolt bits from McMaster. They are a bit harder than the HSS bits but not as fragile as carbide. I have used them in harder material. I had a real problem with loosening drive shaft bolts. I ended up taking the nuts, placing a chisel across the face and giving it a solid whack. It peens over the edge and stopped my loosening problem. Safety wire is probably a better idea though. I may go ahead and do this when I assemble my CVs. Keep us posted on how it works out
240z lower quarter panel replacement. Yay or nay.
LLave replied to 5 Star Rising's topic in S30 Series - 240z, 260z, 280z
I should have looked at the pictures better. Typically these repairs are done with a butt weld, you do not over lap material. If you do, you need to bend an offset flange. Harbor freight has an air tool that punches holes on one side and offsets on the other. You are going to have a hard time blending a piece that is stacked like that. For you to grind it flat, you will have to grind all the way through your new material. I would rethink your approach. Cut your patch panel to fit the hole, to make it easier to weld and to fill the holes you drilled, add some material behind to make a flange. Like this: -
Tube chassis, twin turbo, sbc 350, 4l80e
LLave replied to Tim Blythe's topic in S30 Series - 240z, 260z, 280z
It is a super cool car. Might want to look into Fuel Safe discriminator valves, its a little float that blocks liquid but lets out air. Also, coiling the vent hose once can help too.- 10 replies
- twin turbo
- sbc
(and 13 more)
Tagged with:
Take your time. Get the fit really good. Leave a little gap, about the diameter of the wire you are using. Tack the part in, then slowly ticky-tacky all the way around. The 3M green corps 01991 discs are great for grinding down weld material. Loud and messy, but they remove material quickly and don't over heat the part. They are designed to finish grind mig welds. You got this. -
1970 240Z Race Car Front Suspension Issue
LLave replied to Gmagno's topic in Brakes, Wheels, Suspension and Chassis
Bending the bar and adjustable links might get you there. Do pay attention to the final angle of the link though. If it is less than 90 degrees, it does change the effectiveness of the sway bar. I I am sure that I personally would not be able to detect a small change, but if the angle gets steep it could be significant. http://www.gtsparkplugs.com/Sway-Bar-Link-Force-Calculator.html -
ANOTHER Datsun Z/LS3/T56 Swap Thread
LLave replied to Ironhead's topic in S30 Series - 240z, 260z, 280z
That is amazing. What a tidy looking connector. When I first read 61 pin, I thought to myself, wow this might be overkill.. Nope. Just the right amount. So many wires these days. -
Drag cars do that some times. However, I would be worried about the liquid fuel running out of the vent line in the photo above. Yikes!- 10 replies
- twin turbo
- sbc
(and 13 more)
Tagged with:
I noticed that too. Perhaps the LCA mount is already pushed outboard a bit. Everything stacking up creates the difference. -
Google seems to work some of the time. I put my info in google, the first hit: www.searchpeoplefree.com Totally nailed it, previous address, current... a little scary actually.
I found it helpful to go down to .023 wire, it helped me control the amount of filler in my mig welds on sheetmetal.
Where did you have it dipped? I think its a big subjective as to how pitted requires replacement. I use a little awl, scribe, pokey bit, and if you can poke through the metal, it requires replacement. When replacing, I would take wide margins, or just do full pans. It is way more work to do multiple small patches than one big one. Looks like your car has already been stitch welded though, that would have to be considered, I imagine that makes replacing a floor more complicated. Looks great overall, keep us updated on your progress.
Cut some things, bolt some things, weld a few things, wire, plumb and tune! No biggie!
Looking good! Who did you use to source the wires and connectors? -
broken stud, then extractor...can't remove reminisce
LLave replied to scartail's topic in Trouble Shooting / General Engine
This situation can be a real pain. I have had pretty good luck taking a smaller fastener, grinding a bit of a point on it, then Tig welding it to the remainder of the broken fastener, then grab the new welded on part and twist out. The heat from the tig helps break it loose. Other than that. Stuck extractors suck big time. In car, without a really rigid drill (IE: milling machine), the drill bit hits the hard piece of extractor and wanders, making an even bigger mess. You may need to pull the head and take it to a pro. -
That looks great. Unique too. Can't wait to hear how it sounds. -
Probably true, nothing fits all that great. I was just fitting a new air dam, fussing with getting it centered and equal, pulling measurements to the front of the frame. Then I realized that the front portions are welded different from the factory. There is approx 3/16" discrepancy. This wasn't straight when it was brand new. Gave me some perspective.
Ouch. Sorry to hear about that deal with Carbon Signal. What a shame. The YZ kit will look amazing. Darius' car was incredible with that kit. Great work withe the exhaust. There really is not much room back there. That is part of the reason I went with 2.5" I just couldn't figure out how to get it all to fit. Resonators up near the xpipe are my backup plan to adjust the sound. They can help with LS rasp, should you end up with any. -
I have heard that the knock off rocket bunny stuff typically does not fit well. Just what I have heard, no direct experience.
Great work! It really is not easy. Especially with near zero access to the back side. That will make tons of room. You may have already stated this but, what flares are you running?
