260DET
    15
Everything posted by 260DET
  1. My LS3 is Haltech managed which blocks that solution unfortunately, the Haltech won't talk with the GM TCU will it. Pity. Powertrain Control Solutions have a stand alone controller for the 6L, anyone use that?
  2. Weight is very important for my use, the Ford/ZF auto is a fair bit lighter than the 4L85E lump with the six speeds a bonus plus it is more efficient internally. There is also of course the GM 6L80 which one source quotes at 95kg wet with converter compared with 115kg (? spec) for the 4L85E . As to a controller, there is one vendor who says they have a plug and play controller solution http://tbmsport.com/6l8090eswapcomponents.html Anyone know anything about them? I am going to email.
  3. Good work, I'm not used to seeing Honda's so slow in corners though but you take what you can and enjoy it
  4. The manually shifted 4L85E behind my LS3 280ZX circuit car is old tech and does not have the needed features of modern autos like good engine braking so I'm looking at a 6HP, only problem is for no real reason that I can see, no one else is so info and parts are very scarce. Has anyone moved into the 21st century and is willing to emedukate me
  5. OP you did get a decent variety of response at Classic Cars so perhaps you had better clarify that. Rally prep is a specialised secret men's business, quite simply you won't find those who do this work daily for customers all over the world telling all on the internet and it's unrealistic to expect otherwise.
  6. My LS3 circuit 280ZX has a 4L85E manually shifted behind it, while it's OK the shifts take a while to get the heavy internals moving, it's overall a heavy transmission and engine braking is poor. Compared with what's available in modern performance cars it's an old tech lump. As soon as I can come up with a practical alternative, possibly a Ford/ZF 6R80, the 85 will be put in a museum. It's a pity that you people are not demanding more from your aftermarket transmissions because it sure as hell suits GM for you to be happy with the old inefficient stuff. Plus it makes it hard for those of us who want something better.
  7. Basically all the OE electronics including sensors and wiring will be needed to make it all work like a factory job. Everything interacts with everything else, so everything has to be there and available to work. Bugger eh.
  8. Maybe get a 4L80 instead of the 4L70 unless you are very confident the 70 will be adequate. The problem with going below a certain level of capacity with any component is finding it's not good enough later on and having to replace it with what would have been best first up.
  9. Sounds great for a S30 , my Z31 project car has the original spec '87 rear end.
  10. The good old S30 is a mod favourite now, extreme hybridZ.
  11. Agree that a new thread would be appropriate. G-Tech has a point, it's worth a certain amount to potential buyers so no matter how good a kit is there is always that price point beyond which there is virtually no market.
  12. To each their own and if someone comes up with something that satisfies their requirements DIY then good, relying on off the shelf solutions is becoming a habit and is not what this forum should be about. All I'm trying to do is to recommend a better starting point, to put it practically wide front wheels requiring zero off set put a lot of leveraged load on the stub axles which then are likely to flex and throw the suspension alignments out under heavy cornering. But if that is not relevant to the OP's use then ignore.
  13. With any MacP strut side load is the enemy, it tends to bind the essential vertical movement of the strut but is an intrinsic part of the design. So anything that reduces side load is good providing the correct geometry is maintained. That's the primary consideration here. What is rarely discussed are low friction design strut dampers. Just as important.
  14. Banged the front of the 280ZX wrecking the aero and a few other things at Bathurst this year but why not drive around with the camera on and enjoy the scenery
  15. For someone who has not driven a 370Z they strike me as the modern version of the S30 if we ignore the appearance. A friend of mine races one, the weight was stripped back to 1,200kg race weight including a FIA spec cage. Hello Those In Charge, let's not ignore the 370 any longer
  16. Just ran across this hidden weapon, be good if you put some incar vids in the motorsport section.
  17. Seeing that there are no objections I assume that the suggestion is accepted
  18. Don't know the details but it's naturally aspirated, nothing very special in capacity. Pretty light car too and quick through the corners.
  19. For a change, how about you say what you would be prepared to pay for such a kit. It looks like it would require to be bonded to fit, are you prepared to do that or pay to get it done? I mess around with some fibreglass body stuff, given the time that can be involved often there is no profit to be made, people just won't pay.
  20. We have a 350Z category and the 370Z has not escaped the dreaded LS engine transplant scourge, looking around there is no particular site that caters specifically for modded 370's so maybe? After all hybrid Z's don't stop at a particular model and some fresh site traffic would do no harm so is a 370Z category possible, a good idea?
  21. So this project involves fixing up rat damage? Lol, as long as they didn't piss in the car much, highly corrosive rat urine.
