The time has come, I finally made it to the dyno today! Tuning was done on the Dynapack at the shop I used to work at, Works Motorsports at Sonoma Raceway.
Swami joined for the day, driving in on my old 260Z which he's done a great job cleaning up! We did some carb-sync work on it while he was there and I took a test drive for old time's sake. That Z is so dialed!
I played with various combos of jetting along with the crappy F11 e-tubes and ended up at 135/F11/110 (main/tube/air). This was the best combo I found from my Weber stash but far from perfect, as there is a big rich spot that's causing the torque dip in the midrange that I minimized but could not get rid of. The F11 tube is to blame, I'm planning to alleviate that...
Once jetting was done, I played with timing. First using the ZX distributor and then the 123ignition tune-able unit. I optimized timing with the E12-80 before swapping to the 123. Interestingly enough, I didn't get any appreciable peak gains from the 123. I have a feeling that if I clean up the midrange fueling, the 123 may make more of a difference. All said and done, peak timing was 34 degrees.
Needless to say, I was very happy with the results and surprised that I could run at 11:1 compression with 34 degrees of advance on 91 octane! Guess I have the P90 to thank for that. When I originally build this motor, I was hoping for 200hp at the crank and I almost hit it at the wheels!
The yellow line is with the mesh filters and the red line is without. Looks like those filters are worth about 6hp.
I'd like to do another dyno visit in a few months to address the mixture issue and play with cam timing, either with the stock sprocket or an adjustable one (which I'd have to source).
Very happy with this! Videos to come as Swami was the videographer for the day.
