Leon
    25
Everything posted by Leon
  1. Yes, that's what the proportioning valve is for.
  2. 1. That is friggin awesome!!! 2. That's one hell of a cam. High RPM powerband and better suited for racing than street driving. Degreeing will be difficult without a cam card but you did your work and had Isky profile it. Now that you have the specs, why not set it up again and see what you find? Have you read the cam degreeing sticky? BTW, what octane were you running/plan to run? Will this be a street or track car?
  3. Wow, great work! I wouldn't be ready to commit now, but would definitely be interested in the future. It's nice to have something that was actually engineered rather than haphazardly pieced together. I can appreciate the effort you went through. You may already have it, but Fred Puhn's Brake Handbook is a worthwhile read.
  4. Dear god, that is not the kind of Z you want to get if you're willing to come to CA! You should be able to find one without any holes or cancer with relative ease in the drier climates. Tony summed up the "refundable" deal well. No point of putting in a deposit if it's refundable... I hope you have some money saved up... That kind of car won't be cheap. If that's what you want and can't settle for a later car, when you find a car ask the seller for detailed photos of all areas that you would actually inspect and try to get a forum member out there to check it out for you. If it's to your satisfaction, put down a deposit and fly out.
  5. I've had a check mailed to me as a deposit for a car. The guy came 2-3 weeks later and picked it up. You have to build a trust with the seller to be comfortable. Talk to the guy on the phone. If any part of you has doubts, don't do it.
  6. I'd be surprised if he answered since that post is 6.5 years old and jaime240z hasn't logged in for almost a year...
  7. I like the soft-line idea, also curious about implementation.
  8. Yep, I've begun seeing ads as well... I'll gladly donate more if it's needed to get the ads away.
  9. Looking good, Matt! This is the fun part. I should get a capture of my map...
  10. Awesome! That's exactly the setup I've been thinking of going with on my green car. Do 225/50-16s not fit? Any fender lip modifications? Got any more pics?
  11. Fun stuff indeed! It should spin freely past 7k RPM but retain decent mid-range grunt. I wish I could race through 8k RPM but I don't think the pistons would like that very much. I'll be using a 10lb Tilton flywheel but undecided on clutch so far. I have a brand new stock clutch that I can use but unsure of how much stress it will take. Great info on the springs, thanks! I was going to do just that, talk to Isky and see what they think. I think I'll end up being OK without any spring spacers, it was just a note I wanted in there so I keep it in mind. I'll take you up on that generous offer! I'll take the head gaskets. Just let me know how much and where to send monies to cover postage.
  12. Current to-do/buy list: - Regrind rockers (I know Delta Cams does it for a good price) - sourcing 2mm/0.080" cam tower shims (considering making these myself or buying from Derek) - sourcing longer valves (Rockauto or SI) - low profile valve stem seals (FEL-PRO SS72686, thanks for the tip Leo!) - figuring out my cam and springs, lash pads may need replacement (Isky) - Head gasket (unsure...) - Manifold studs and gasket (MSA/Rockauto/local) - Valve spring shims (not yet found)
  13. Thanks Jim! I'll be assembling the head myself, so no custom cam yet. If I run into an issue of a custom grind being way too expensive, I'll have to settle for Isky's Stage 3 as I think it'll be close to what I'm looking for. Either way, I'd like to experiment with a custom grind at some point, even if it doesn't happen this time. I'm still working on my cam sizing spreadsheet. Still need to figure out minimum lift and overlap numbers... The triple Webers on my orange car use the stock fuel rail, with the feed coming in at the front carb, daisy-chained to the rear, and back into the fuel rail. I plugged the return almost 2 years ago when chasing a fueling issue (turned out to be the filter) and never unplugged it, although I probably should. I've not had vapor locking issues though, even in 100deg+ heat at Long Beach last year. On this Z, I'm doing away with the stock rail altogether and will be using AN lines, with a return. Good thoughts on the head gasket and piston-to-head clearance, I'll report when I find out.
  14. Block, crank, rods, and head are in the machinist's hands as of Saturday! The block may need to be bored because of rust in the cylinders but otherwise nothing special. Crank will be polished and balanced. Rods, pistons, flywheel and clutch will be balanced as well. Head will be the "typical" modified P90: shaved 2mm, longer valves, yadda-yadda... I just ordered some ARP hardware for the rods and mains. The to-do list, posting so I don't forget something (always happens): send out the rockers to get reground, sourcing 2mm/0.080" cam tower shims, sourcing longer valves, low profile valve stem seals, and figuring out my cam and springs. We'll see what happens with the lash pads. I will need to finalize fuel lines and routing as well. Can't wait to start putting this thing together!
  15. Holy crap, unbelievable is right! That's a crazy deal you got. Luckily, it sounds like you have better taste than the PO...
  16. I run HTR Z3 on my S2000. Great grip, super affordable, and no excessive noise that I've noticed. I got them because of their "bang-for-the-buck" factor.
  17. It's definitely the latter! I hate that clevis and cotter pin... I have to use long needle-nose pliers, no way in hell do my hands fit up there.
  18. If you get a "JDM" engine, it won't be smog legal unless it has been certified for use in passenger vehicles in the USA. You'll have to put in due diligence to perform a smog-legal swap. I recommend finding a stock engine and wiring harness unless you really know what you're doing.
  19. Great job Matt, it feels good to be on the road. Don't worry, I'm sure you've done a good job on the install. Given that, the system should be very reliable. The bang was due to your soft limiter. Going WOT at 5k RPM and suddenly retarding timing to 0deg would definitely cause that.
  20. Sweet, thanks! I had no idea the Redline mani had a (partial) balance tube. I should check my TWM... The zero bleeds were part of the final stage of tuning: accel enrichment. I wasn't getting enough of a pump shot so I increased the volume by not letting any fuel bleed back into the float bowls. This was part of what cured my low-RPM pedal-stomp stumble. Tell me about it! I'll keep you posted.
  21. Sucks to hear Ross, hope you get back to "normalcy" soon.
  22. For the archives: it's either an '84 200SX or '80-'86 720 Truck FS5W71C, as I posted in your other thread. http://www.gracieland.org/cars/techtalk/gearing2.html
