jhm
Super Moderators
    24
Everything posted by jhm
  1. Yes, they are quite good IME. I run both the BP10 and BP20 compounds, and even the softer BP10 are quite adequate for 30-minute heats at the track.
  2. Cool find...thx for sharing. I’ve looked at KW stuff before, but it’s always been out of my price range.
  3. ...or ClassicZcars.com. They’re very big into original parts for restoration purposes.
  4. FWIW, I used to run a set a wheels that were 14x8, et0 with 225/60 front and 235/60 rear with stock-configuration suspension (Tokico lowering springs on stock strut housings) and custom steel flares. Did not have rubbing issues on the inner side, so I suspect your wheels with -13 offset should be ok in that regard. I think the biggest potential issues you might run into in the future (besides the obvious issue of performance tire availability) is the limitation of options on upgraded running hardware (e.g. brake upgrades, adjustable tie rod ends, adjustable LCAs, bump steer spacers, etc.) If any of those upgrades are on the horizon for you, trying to fit any of that stuff in a wide 14" wheel will not be easy, if not downright impossible. Nice-looking wheels, BTW!! 👍👍
  5. Nice video, @Sanchez -- thanks for taking the time to produce it. Looks like a great candidate for a Sticky in the FAQs, IMHO.
  6. Aydin, at the risk of stating the obvious, double-check the recommended max extension for those double-adjusters in your front LCAs....should be a combination of the number of threads engaged (on both ends) and length of exposed (unengaged) threads. The convenient thing about wheel spacers (and spacer adapters) is that they can be quickly added or removed without affecting front end alignment, and they can also be used to easily fine-tune your effective spring rate (both the strut springs, and the anti-roll bar if applicable).
  7. FYI for @dorothytaylor61jy (and anyone else interested in this)....if you're unable to contact @Randalla here on HBZ, he also sells the book on eBay. I just bought it there and had immediate communication from him regarding the sale and shipping info. https://www.ebay.com/itm/224939391356?hash=item345f6eb97c:g:ocoAAOSwvmJiWZno Excited to read it!
  8. Have had nothing but good experiences with usedracingtires.com, that Clark mentioned, and usdrrt on eBay (https://www.ebay.com/str/racetiresusdrrt?_trksid=p2047675.m3561.l2563). USDRRT always had a good selection of nice-condition cantilever slicks at really good prices; but I haven't bought from him in a while so am not familiar with his current inventory. He always seemed to have a lot of SM tires, so that might suit your needs nicely.
  9. Looking good, Clark! Since you’re this early in the fab stage, how about modding those strut towers so you can remove the shocks and springs out the top (vs having to lower the LCAs and swing the strut tubes out of the fender every time you want to make changes)? I’m always envious of the Mustang guys that can easily pull their struts out the top of the towers.
  10. I would tend to agree with Aydin...does seem a little gimicky; but then again, it’s only $50. If you like the idea, that part is easily fabricated DIY, but make sure it’s easily removable (I.e., not welded) to ensure ease of removing your MC when you need to. If your firewall is structurally sound, it should be plenty strong for street use with the occasional track day. If you’re concerned about it, just reinforce that area while the car’s on the rotisserie. I guess I could imagine some possible firewall flex if someone were running their car without brake boost, which obviously requires a lot more pedal force to achieve the same level of braking.
  11. NCRAs are another method of obtaining additional track width (on the front) without resorting to wheel spacers. But they can result in interference between the LCA and the wheel, depending on what size/style/material wheels you're running. It's all a bunch of trade-offs.....just have to decide which setup will work best for your particular application. https://technotoytuning.com/nissan/240z/evolved-roll-center-adjusters-datsun-240260280z
  12. No, it's not IME. As Jon mentioned, it generally results in a performance decrease. Most people with adjustable TC rods use them to increase caster; which improves straightline stability and allows one to run less static camber (for better straightline braking) while still demonstrating good dynamic camber characteristics while turning (when the additional negative camber is most needed). Keep in mind that adjustable TC rods are designed to run in conjunction with adjustable front lower control arms, which use monoball heim joints for frictionless freedom of movement through multiple axes. The stock front LCAs, which use OEM rubber bushings or aftermarket Delrin bushings, do not enjoy such freedom of motion and will bind if stressed beyond their intended range of motion. You didn't say what width wheel spacers you're using....but keep in mind that the thicker you go, the more they will affect your effective spring rate (results in a softer effective spring rate). If you are using "thick" spacers (1" or thicker), you should be using "wheel adapter spacers", which incorporate their own wheel studs. https://www.ezaccessory.com/Hub_Centric_Wheel_Adapters_4x4_5_To_4s4_5_p/4450-4450ha.htm. If you're worried about the asthetics of the wheels not being centered in the wheel well; you can always factor that in when selecting your mounting locations for the new flares.
  13. Yep, that link worked. Thanks for the reference data! @fusion, the discussion may have gotten a bit off track....but did you get the info you needed to make a decision for your 280?
  14. FWIW, my experience is that any of those "smaller" rear spoilers essentially do nothing for downforce. (They can help in cleaning up the rear airflow of the car to reduce in-cabin exhaust fumes.) I can't point to any specific aero testing; but IME you need something like a whaletail, or a tall wing, to measurably increase your aero downforce on the car. Similarly, front airdams can help with engine cooling by creating a negative pressure cavity under the engine compartment. They can also increase high-speed stability by eliminating pressure buildup under the front end of the car. If your car is a "street car with a few passes at the dragstrip per year", I would get whatever you like aesthetically. I've had the BRE spoilers front and rear on several of my cars, and the look is timeless IMHO.
  15. The C-clips are internal to the differential center section. They snap into the machined channel on the splined section of the inboard ends of the side axles -- that's the click one feels when people talk about the side axles "snapping" (or "popping") into the diff during installation. Hope this helps explain it.
  16. Your prices seem pretty reasonable to me. The Euro-style tail lights are particularly desirable, IME. If you haven't yet done so, I would advertise them on ClassicZcar.com and the S30 pages on FB.
  17. I did exactly what Jon did on his, and it hasn’t been a problem in three years of track and street use. Those billet brackets look nice, but I just used an extra set of the OEM rear u-brackets on the front LCA bushed mounting points....they’re the same shape and size front & rear. I have seen failures at those LCA forward mounting points; but only on mega-HP/tq setups with drag slicks.
  18. First off...if you haven't yet read this thread, I would start here. 109 pages of different wheel & tire combos. Many of the early photos are NLA, but anything in the last few years should still be viewable and entirely useful. https://forums.hybridz.org/topic/58528-wheel-show-post-your-pics-of-you-wheels/#comments Also, as @Michael pointed out, your biggest LIMFAC is often the strut spring perches interfering with the inner side of your wheel/tire. Just because a particular wheel/tire combo fits within the Z's outer sheetmetal doesn't mean that it can be used without other modifications to your brakes or suspension. This is one reason that so many people convert to adjustable coilovers with smaller diameter springs (2.5" ID is very common, and much smaller than the OEM strut springs.) I'd be surprised if 15x8 fit inside the stock sheetmetal without interference with the strut spring perch; and there's no way a 15x9 would fit. As @Dat73z illustrates, you can fit a 15x8 inside the stock sheetmetal...provided that you have swapped the stock springs for an adjustable coilover setup. Hope this helps.
  19. What’s the intended application for the car and what’s the rest of your setup? Is your priority on aesthetics or performance?
  20. Sounds like an insane build! Subscribed and following!! Good luck with it.
  21. @danc430, that's a really good find on your part -- thanks for sharing!! I agree with your assessment on the pricing; but that's hard to measure since the stock ZX calipers seem to be NLA. (I looked for a couple of months when I was considering using the ZX calipers with vented front rotors on my 260Z; and had zero luck finding those OEM 280ZX calipers.) If you do decide to purchase this kit, please post your impressions once it's installed...I'm sure a lot of folks would be interested to hear how well it works. As a bonus, for anyone wanting to upgrade their stock S30 front disc brakes to vented (a la the "Terry Oxendale upgrade"), this kit would seem to include everything needed except the rotors, which are readily available from anyone (I found the best pricing on RockAuto last year, FWIW).
  22. jhm
    Weatherstripping
    Hey @fusion, sorry for the late reply; but no, did not use any kind of sealant.
  23. Good call, Aydin...strengthening the end link attachment points. Also, with your adjustable LCAs, keep in mind that whenever you lengthen them (for increased track width, additional negative camber, etc), you are also reducing the effective spring rate of the suspension...both the coil over springs and the sway bar springing. Changing one element of the system can affect so many other components. Can’t wait to see your car up and running!
  24. Another way to incorporate adjustability into the system is via the end link mounting brackets (that are bolted to the LCAs). You can fabricate brackets with multiple holes, to allow for multiple mounting points for the end links. Or you can make a bracket with a single mounting point that is “off-center” (I.e. slightly inboard or outboard of the carriage bolt used to mount the bracket on the LCA) — for adjustability, flip the mounting bracket 180 degrees to position the end link mounting holes to the “more inboard” or “more outboard” position for stiffer or softer effective sway bar springing. Hope I’ve explained that in an understandable fashion. The more options you have for adjustability and fine-tuning will be especially helpful when you’re at the track, with limited time and facilities. I’ve looked at the cockpit-adjustable and blade-style sway bar systems with envy, but have yet to engineer a sufficiently durable and cost-effective solution. One of the many items on an infinitely-long “to do” list. 😆
  25. Not my car; don't know anything about it...but seems like it could be a great start for anyone wanting a project 240. https://www.facebook.com/commerce/listing/467641471636318/?media_id=1&ref=share_attachment
