clarkspeed
    50
Everything posted by clarkspeed
  1. If you want to minimize bump steer and are not bound by rules, a small 1/4" vertical slot, not slanted, in the cross member (combined with strut spacer if you have lowered the car) is usually all you need. Quick and easy adjustments. And it doesn't take a $150 gauge to get in the ball park. I use what amounts to 2 square pieces of wood connected with a piano hinge. I place weights on it to keep it from moving on the floor. The free side leans against a wheel with what amounts to 2 nails resting on the wheel outer shell about center height. Adjust it until you get both nails touching equally. Remove the springs and sway bars, jack the car up and down through normal range of movement, and watch how far one of the nails will move away from the wheel. It usually moves A LOT. Adjust inner pivot until you can keep both nails touching through the entire range. I think I mentioned before, 0 toe in the rear of my car really added to high speed stability. But your speeds are another deal.
  2. Hey, I only said a "little" different. Point being you can get parts from China manufactured to any quality level you desire. But a crank manufactured to the standards of Sichuan Andes may not meet your expectations and shipped in a box packed full of risks. I have not experienced any bait and hook tactics with my suppliers. But again my products have detailed specifications. It is also a long path to qualification so suppliers that invest into that dont want to lose out due to quality problems.
  3. Oh and the original subject, if Scat or Callies, or other reputable supplier put their name on it and stand behind the quality, then made in China is no big deal, maybe even better. But I don't think I would buy anything off Ali Baba with unknown quality standards.
  4. I would say my observations are a little different. All of the OEM gas turbine manufacturers have significant Chinese content. Things have changed drastically there in the last 10 years. For the most part, materials, processes, and quality are on par with anyone else in the world, but you have to commit considerable resources to get it. Well defined specs are necessary. And companies like GE assign their engineers to stay there and work the technical problems. Like anywhere, there are good companies and bad ones, and definetly more risk of IP and trade secret loss. The suppliers I manage there are very impressive to say the least. BTW you can buy stuff from India for about 1/2 the price of China. But that is another story.....
  5. "Made in China" is in no way a label for crap. You would be amazed at what OEM manufacturers export from China whith the highest grades of alloys and precision manufacturing capability. It's all in the specifications and what quality you desire. On the other hand, if the part was not designed by a reputable company with robust quality control, then you may well be buying crap no matter what the country of origin is. And yes, you usually get what you pay for.
  6. Little tip. I installed a pair of tie down rings in the outer nutplates just behind the seats. You can easily reach under the car blind and hook on tie down straps in the trailer and allows the rear straps to run parallel.
  7. Curious why you would be selling those.
  8. Tragic indeed. Did not know John personally, but I can attest he was one of the few truly knowledgeable, helpful, and insightful contributors to this forum. Not many people "get it", but John did. A great great loss for the Hybrid community. I took for granted that his response was always there, with just a few hours delay, for so many years.
  9. Wish they would do some 3.3, 3.1, and 4.3 R&P sets
  10. I tried to lower the best I could on the car I am building now. I used a different steering rack mounted slightly lower and dropped the engine until there was less than 1/4 inch clearance to oil pan. I dont think I gained much. I also moved the engine about 1" to passenger side for weight distribution.
  11. That is interesting. Have any pictures of your pan?
  12. I finally got around to dragging it down. It may have less clearance than a stock pan! The "sump" is a 4"wide tray that runs the length of the pan on the drivers side. It measures about 3" from block to lowest point.
  13. Derek, I definetly see a Bill Coffey garage party award in your future.
  14. I have an ARE pan on the shelf. I could take some measurements if you want.
  15. Bilsteins are bulletproof. I can't blow them, and even if I did Bilstein will rebuild for $80 and valve any way I want.
  16. Could not have said it better myself. Everything is a compromise. Especially with a strut suspension. You can really get wrapped around the axle looking for some perfection that is not there. And everything you change has at least a primary and secondary effect. So think about that when you start turning screws on those trick adjustable parts and drilling cross-members. But with that said, I don't think there are any negatives to getting rid of bump steer......
  17. I think every rebuild I have done myself cost $1400-1500 in parts and machine shop. For budget, I say keep it stock and invest in intake and exhaust as required. A little "free" power can be had by port matching manifolds and blending the port into the valve seats on some heads.
  18. From my experience, large movement of the inner pivot makes the bump steer unmanagable. I prefer controlling the RC and camber by other methods. Then bumpsteer can be mostly eliminated with a very small vertical slot in the cross member of 1/4" or less.
  19. Those TTT control arms look just like the set I recently fabricated. I got the monoballs and pins from UB Machine. My theory on bump steer is I dont worry about measuring it.....just try to get it as close to 0 as possible. No expensive tool needed. Just 2 pcs of plywood, piano hinge, 2 small screws that extend out to touch rim, and a weight to hold on ground firm. Remove spring and jack car through range of motion. Adjust until screws ride on wheel rim throughout range.
  20. Bumpstops and packers - the secret sauce for Chumpcar racing.
  21. Look up the stud kit number on ARP website. It links to their correct torque spec. Not unusual for older block to have some corrosion in the threads if water ever set in there.
