NewZed
    71
Everything posted by NewZed
  1. Actually, Wagner's description fits. "Unfueled" air is drawn in to the intake manifold. Seems very crude. And this was 1981. Apparently the PCV and carburetion system are tuned as a complete system. Here's a pciture from the 1981 truck service manual.. They even call out the "dirty" air, apparently it's not even pulled from the filter side, Funny story - I helped a friend get his car running after he filled it way over with oil, soaked his air filter through the PCV hose, and the engine wouldn't start. I threw the filter away to fix it.. He didn't know anything about engines (hence the overfill) and had beat the piss out of it which caused much of the oil vapor to get pushed through the hose. I told him to take it easy, the motor was on its last legs. He beat the piss out it again that night ( a bunch of us met later that night and he was complaining about the smoke) because it ran so much better, parked it in front of the house with the room he was renting, and woke up to a muffled boom as the oil on the super-hot exhaust manifolds caught on fire. Burned to the ground. I think it was a Yugo.
  2. Sorry about that, forgot about 77 and 78. By the way, if you want to look knowledgeable when stating that someone is wrong, you demonstrate why. Like I just did. Edit - more knowledge. 1975 and 76 don't have hood vents. That's where I got the idea.
  3. Here's some interesting reading - http://speedtalk.com/forum/viewtopic.php?f=1&t=37104&start=0 http://mewagner.com/ Here's a fair summary of the basics. They still seem a bit confused about where "fresh air" comes from - http://mewagner.com/?page_id=434
  4. 280Z's don't have hood vents.
  5. Derek, your avatar still shows that old dinosaur head.
  6. He built his own head. How'd you miss it? I think he's running ITB's also. I posted in front of you. A good catch can would probably keep your carb clean. Cleaner for longer anyway. More hoses though.
  7. You'll pull "unfueled" air in to the intake manifold that way. It will not have passed through the carburetor. It will lean out your mixture. That's why the systems that use intake manifold vacuum are "sealed" systems, and the open systems empty before the carburetor. The hot rod V8 guys have this same problem. You might search around those sites. I think that one reason for using a PCV valve on whatever you use to pull through the crankcase is that it controls flow. If flow gets very high the spring will compress and the valve will close. The PCV valve is essentially a two-way check valve. You don't want huge volumes of air passing through pulling all of your oil out in vapor form. That's why people use catch cans. Fix on top of fix. It can get complicated. Before PCV they just left the crankcase open with a breather type filler cap. Probably got messy with old engines.
  8. The bleeder should be at the highest point of the internal passages of the caliper. That's the basic principle. Some people tilt the caliper, I imagine you could tilt the car to get the same effect. Whatever it takes. Bubbles rise. Be the bubble.
  9. Use a meter and measure voltage at various places along the path to making the bulb filaments glow. Or measure resistance to find which components or wire paths aren't allowing current.
  10. Is it possible to get the bleeder on the bottom with the Wilwoods? I notice in your pictures that the "d" is up on end (front or back), and the "w" on the other. If he plumbed the front and rears differently and you got the calipers swapped, you'd have a bleeder position problem. On the stock system, the calipers will swap side to side and cause that problem.
  11. I meant the FS5R90A or FS5R30A versus the FS5W71B or ...C . BW versus Nissan. Left out the wrong letters. I thought of why the slave piston might not pop out if the short collar is used with the short pressure plate. Maybe the back of the fork bottoms out on the edge of the hole in the case. It would probably leave a mark.
  12. If the rotor is freshly surfaced the pads will just make a new path. You could have the wheels balanced with the hub and rotor bolted on. I've not seen it done, but it seems to make sense even without a runout problem. The casting inside the vents looks pretty rough. Can't be that well balanced from the start. After balancing you'd want to mark the wheels to the hub to keep them indexed. Or you could do a wheel, then bolt the hub and rotor on and re-run it to see if it even matters. Don't forget to also have your machinist take the edges off so the wear pattern doesn't look funky. Kidding... This is kind of like the assumption made for internally balanced engines, and flywheels, and pressure plates. Each part is assumed to be "in balance". If you start looking a round there are all kinds of ways to be out of balance. How many people rebalance their wheels after rotating tires? Of course, the racers probably do, but still. Most of us wait for funny noises. http://www.brakeandfrontend.com/on-car-wheel-balancing-wheel-to-hub-indexing/
  13. You're not getting the whole picture. The collar and the pressure plate are a matched set. There are several pressure plate heights and several collars to fit those plates. The matched set should have the ears of the collar 92 mm away from the flywheel surface with the collar in position on the pressure plate release levers (fingers). Hold a straightedge on an ear and get that measurement. I will never install a transmission in a Z without ensuring that 92 mm distance. +/- a couple mm probably okay, but 92 is the target. Several others have verified it. It works because the pivot point for the clutch and the mounting position of the slave are the same across many years of Z's and ZX's. 71B and 71C transmissions. Not sure about the FS5... series. Likely the same though since the same clutches are used.
  14. The headlights and signals are easy to figure out and fix. You'll probably wish that you had never had this thought. Browse through the wring diagrams here and see if it still looks like fun - http://atlanticz.ca/zclub/techtips/electrical.htm
  15. Since you have the clutch exposed now you can address z-ya's suggestion about the collar. It's the distance from the two ears (on the collar) the clutch fork sits on, to the surface of the flywheel that matters (assuming that the flywheel is the factory-set distance from the engine). That distance should be about 92 mm. You didn't answer the question about if the kit came with a new collar. Or if you checked the slave boot for fluid. Or if you measured stroke at the master cylinder One thing on the slave travel distance - it's seemed to me that the slave piston would get pushed out of the bore if the short collar was used, since the next stroke after the master cylinder refills should "over-stroke" it.. Since the slave piston gets pushed back in its bore only as far as the fork pushes it in it would start way down its bore. A long collar stopping full engagement makes sense but I can't figure how a short collar stops disengagement. It should just allow the slave piston to pop out. If you've already put it all back together you can get an idea of how far down the bore the slave piston is by pushing it back in by hand when it's mounted. It will just push fluid back in to the reservoir. Wouldn't be surprising if you just had a bad seal in the master cylinder. There are two seals, one to create pressure and one to keep all of the fluid inside. The pressure-producing seal (primary cup) can leak inside without an external leak.
  16. Cheaper to just mount the fuel pump in rubber. BMW made a nice rubber capsule for the Bosch external pumps on their older cars. But even a rubber washer under the mounting points will make a difference.
  17. That's a mistake in some database that's out there. I actually sent the manufacturer that started the whole mess an email about it and they said that they had just assumed that all of the halfshafts (drive shafts) were the same. Too late, they couldn't fix it, now it's out there for ever, like rebuild kits for FS5W71A 280Z transmissions. CV half shafts didn't show up until 1981.
  18. Actually the thought crossed my mind. But stating equal distances implies equal diameters, hydraulically speaking. You can only elucidate so much on these forums. Besides that, he sad that he was not in spec on distance, by the FSM. 0.4 / 1.378 = 0.29. That's a giant slave or a tiny master. Reman cylinders are known for grit grime and poor quality. He might have a dust boot full of fluid.
  19. Might get more response if you just asked for the whole backing plate. Not positive also, but they might vary with year. Later 280Z drum brakes are different from early, for example.
  20. If you've done all of these things, then check the slave cylinder dust boot for fluid. It might be leaking. The reason that the pedal adjustment is so important is that the slave cylinder piston will only move as far as the MC piston moves. That's how hydraulic systems work. If you only get 0.4 inches of movement at the slave cylinder, and there's no air in the system, and the cylinders are the same diameter, then the MC piston is only moving 0.4 inches. That's the basic principle. If you want to get rigorous, measure the distance the end of the MC rod moves, at the pedal. It should be 0.4 inches, if you have a properly bled, non-leaking system, and the slave only moves 0.4 inches. Slave follows master. If you have more movement at the master than the slave, there's a problem in the hydraulics. Break it in to its two parts, mechanical and hydraulic.
  21. If you have tiny fingers or are good with a tools, the simple way to check the MC rod length is to remove the clevis pin. If the clevis hole isn't lined up with the pedal pulled up to its stop by its spring, it's probably too short. Actually, that adjustment should be made when the MC is installed. Makes it much easier to get the pin installed. p.s. if you have fat fingers or large hands, you can run a thread through the hole in the clevis pin, then run the thread through the pedal and clevis holes, and pull the pin in to place.
  22. AZC shows a simple way to get PCV. Not very sophisticated, it's before the carb and depends on vacuum inside the air filter housing to create vacuum. The worse the air filter the better the PCV pull. Plus it oils up the carburetor. http://www.arizonazcar.com/cableinstall.html You could plumb the manifold and use a PCV valve. That's how Nissan did it with the 240Z's. Read up on them and you'll get some ideas. The carb stays clean, gases are purged. The crankcase has to be sealed, so you can't run a breather and a PCV. Edelbrock has a PCV port on the carburetor itself - http://www.edelbrock.com/automotive/misc/tech-center/dl/carb-owners-manual.pdf Looks like some Holley's use the same port for PCV and brake booster. You could do that. http://documents.holley.com/199r7950-7rev7.pdf Of course, if you use the 0-8007 390, you could just use the PCV port already there. http://documents.holley.com/199r8108-2rev4.pdf A sealed crankcase and a PCV valve is probably the cleanest way to go. The problem with the sealed crankcase is that you need a way to let off pressure from blowby at high RPM, open throttle. Like the EFI systems do. Not sure how the carb guys do that. Probably why they run them open with catch cans. Could be that they just run the hose to the carb, but no PCV valve. Seems like the power brake system would get oiled from crankcase fumes if it's T'ed in there. If I was building a system, and wanted it to stay clean, but avoid over pressure in the crankcase, I'd probably put a check valve on the valve cover with a breather, one-way vent to the outside, and use a PCV valve on the manifold with the carburetor port. Or run the valve cover line to the air filter, like AZC shows. Still with a check valve though. Not sure where you'd get that valve. There's probably a thread out there somewhere in which somebody has gone over all of the PCV permutations for a carb setup.
  23. I would guess that this is your problem. I'm not sure what you mean by "any if possible" but the clevis at the master cylinder rod can be adjusted where it attaches to the pedal. You can do it with a pair of pliers. Loosen the lock nut and turn the rod to make it longer. Run it out until you get proper play at the pedal.
  24. Yes, the internal clips were used up until the VLSD diff's I believe. VLSD has clips on the axles, older open and CLSD had internal clips. They should still be in yours. They were probably part of the problem you had removing your axles. Might be damaged by now. The clips keep the axle located in the diff. Otherwise it would be a battle between the halfshaft compressing and extending or the axles moving in and out as the distance between diff and hub changed.
  25. You might have a memory from when you had it part of what is involved in "going in to gear". Not much. A coupling sleeve with internal teeth moves over a synchro ring and the external dog teeth on the gear being engaged. Three little pieces of metal (inserts) compress three little springs along the way. So rust may be a factor since the coupling sleeve and the gear will rust. If the synchro cone on the gear rusts that will hinder the synchro ring aligning the teeth. Could be a factor. The shifting rods can rust also. Aluminum can build up an oxide layer also, so the holes might be gummed up. So, if ti worked "okay" years ago, it will probably come back to at least that level. I had an old transmission that sat for years, that worked itself in to better shape after a few miles of driving and picking the right fluid. My best guess was rust on the parts that need to be smooth to work right. Your best path forward might be to just drive it. Start it in 1st gear if it won't engage with the engine running. Match RPM while you're trying to wear it in. For $80, not much to lose. Here's a video of a guy shifting his FS5R30A transmission, with both cases removed. Lots of other good pictures also. http://beergarage.com/PathTransmission9Shift.aspx
