NewZed
    72
Everything posted by NewZed
  1. If you use a ZX distributor with the ignition module (black box) intact, aren't you using a module to trigger a module? Instead of the sinusoidal signal, the output would be square. You should be able to take the ZX module off and just use the wires inside from the magnetic pickup, if i understand the MSD instructions correctly. Wondering. I've never used an MSD but it's tempting, to try to smooth out the idle a bit.
  2. It's not a bad start. Probably a lot more in there. The other guys know much more than I do about extracting power, I'm more interested in seeing what Datsun Parts LLC is putting out for product. Good luck with it and thanks for posting the dyno results. It does seem odd though that the shop didn't take any AFR readings at all. The results would have been more valuable, especially for a baseline for future tuning. Maybe they broke all of their O2 sensors and didn't want to waste a session.
  3. It's a Datsun Parts LLC motor. I don't think that he's a professional builder of performance engines. Not saying he doesn't know what he's doing but he doesn't have a track record. I'm really not trying to bash on your engine or the builder. Just saying that he might be just a guy learning as he goes. Edit 2 - Curious - does he supply a build sheet with the engine with measurements, things like combustion chamber volume or flow numbers, cam/valve timing numbers (opening and closing), distributor specs, etc? That would tell something also about what you might expect from the collection of parts.
  4. Did you get it? Somebody did. I have to be honest (actually I don't but anyway) I put the first bid on, before I realized that it was an Illumina not an HP. I need just one HP shock, and saw the BZ3038, didn't know that Tokico would use the same part number for both (weird). Glad someone will get some use out of it. Auction's over so the link doesn't work anymore.
  5. I think that the purpose is to "pause" or "check" the striking rod when you're pulling down from 5th gear. If you've used an older model 5 speed you know that it's super easy to drop in to R from 5th, there's no check sleeve. It only fits two ways and pops in an out. Install it, try the 5th to 4th shift, if it's too easy or binds up, flip it. You can try it out before you re-install the transmission. You might find that it only works one way. Or you can stare at the striking rod and the check sleeve and logic it out. It might be obvious. I've looked myself. but I didn't put the time or thought in to it. If it makes no sense, I have an 83 in the garage I could take a look at.
  6. Here's a start - http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0&_nkw=bz3038&_sacat=0&_from=R40 One at a time...
  7. You could match up the rust and grime marks. Or put it all together and see which way "checks" reverse. Or both.
  8. Don't you have two pivot lines at the inner mounts? At the bushings and at the spherical bearings at the adjustable rod ends. How will that work? I've been confused before...
  9. Are the three different seals by year? Different seals for different years? I would find out more about the seals. Elimination might leave you with the right one. Compare what you have to what's shown in the PD chapter of the Q45 FSM's. I think that one of the differences might be the ABS rings. http://www.nicoclub.com/FSM/Q45/
  10. I guess I don't understand the flow path then (seriously, I don't). I looked at the illustration in the FSM and it seems to show the path after the filter in the center, down to the main bearings and up to the cylinder head, and the path from the pump in front of the filter, with the gauge port on it. Which seems to fit seeing an increase in pressure if the filter bypass was blocked, and it had been opening. If the gauge port is after the filter then blocking the filter bypass should drop the gauge reading since all oil will suffer the pressure drop of passing through the filter. From which your question follows. My mistake. I have a short block inthe garage but have never had one apart.
  11. NapsZ? Common truck motor. 4 cylinder. It's on the Google.
  12. If understand the flow paths and gauge port position correctly, blocking the filter bypass could actually increase the gauge reading (pressure before the filter) and reduce oil flow to the parts that need it. Giving a false warm fuzzy feeling. A pressure reading from the center supply line to the head would tell more about oil supply and pressure. Ideally, you'd have a guage in the head also, after the restrictor inthe top of the block.
  13. He's from Belgium, there may be a language barrier. English is not primary. Step 14. Using the round file, file the inside of the carrier down until the damper body can fit through it easily. The "damper body" is the "shock body". It's the Bilstein. The hole in the center of the "female carrier" is apparently too small to fit over the body of the Bilstein. A tool (round file) is used to make the hole bigger.
  14. Actually that's a good way to damage an alternator. The current surge can cause damage. But, since it's been done, that would be an indication that your alternator is not generating curremt or it's wired wrong. It's not normal. The better way to test is with a voltmeter. Measure at idle and at higher RPM. Typically a good alternator will generate 14 volts +/- ~0.2. Battery voltage is 12.6, so above 12.6 is what the alternator is putting out.
  15. Did you find out what was makng the "bouncing marble" noise? The original problem? The fabrication and welding work looks good. Hope it all works. Have you tried to fit the bearing back in to the bearing mount you welded in?
  16. For all of the aggravation the other options seem to bring, this kit seems inviting. Haven't really seen any indication of how much power it will take - http://www.wolfcreekracing.com/index.php?option=com_content&view=article&id=72&Itemid=61
  17. You can browse around the site below for part numbers and check at the second one for availability. I saw your other question. I'd guess that many viewers are shocked at the carnage. Most would probably just get another transmission or tail housing. The specs. for rebuilding are in the Factory Service Manual in the MT chapter (also below). http://www.carpartsmanual.com/datsuns30/DatsunFairladyZIndex/PowerTrain/TransmissionCase/5Speed/tabid/1702/Default.aspx http://www.courtesyparts.com/ www.xenons130.com/reference www.xenons30.com/reference
  18. You're talking about the tension/compression rod. People do rubber in the back and urethane in front because all-urethane has led to the end of the rod breaking off in some cases (mine did). Plus all urethane can lead to much more noise (creaking and groaning), at least it did in my case. To be clear though, I did the rods without doing the control arm bushings. I think that the worn bushings put more load on the T/C rod bushings in certain situations. Some people do fine with all urethane, but the urethane in the back only sees real work in reverse. It's a better-safe scenario.
  19. It could be 280Z (two wires that come out of the side of it would lead to an ignition module), 280ZX (it would have a black box [the ignition module] bolted to the side of it) or Mallory Unilite (popular for the 240Z's, ignition module under the cap). Got a camera? Here's the last one - http://www.thezstore.com/page/TZS/PROD/12-4042
  20. What's under the cap? Points or electronic?
  21. You should study up on the basics of how engines, transmissions, and clutches work. You have a ways to go. The Factory Service Manual is actually very good as an educational book, it's worth reading.
  22. Seems like somebody could make a few dollars producing gland nuts if they wanted. They're not very complex.
  23. Tight dowel hole maybe? Or are the holes definitely in the wrong spots?
