tim.d
Everything posted by tim.d
Progress on my insane VQ35HR 240Z project
tim.d replied to markrolston@mac.com's topic in Nissan V6 Forum
I'm kind of upset you're painting it, but more glad it's still alive! -
Front calipers on the rear
tim.d replied to Evandavis73's topic in Brakes, Wheels, Suspension and Chassis
I think you're going to have a really hard time balancing the brake system with equal front:rear piston area. http://www.stoptech.com/technical-support/technical-white-papers/white-paper---brake-bias-and-performance-why-brake-balance-matters Edit: nevermind misunderstood Op -
I prefer imgur, because it gives you BB code for each image and is more specifically made for forum posting Edit: Though now that I test it again, not working. So nevermind, imgur it is for me.
- 19 replies
- photobucket
- album
(and 5 more)
Tagged with:
Flickr, google drive, imgur, lots of other options out there
- 19 replies
- photobucket
- album
(and 5 more)
Tagged with:
Interested in going, are there usually a fair amount of S30/S130s or is it overwhelmingly 350/370s?
I had to replace my engine bay frame rails, and made my own radiator lower support. 2 or 2.5" square: Will need to finish out the rest of the core support panels at some point
There's your issue - can't direct link to the "new content" button. Need to access it through the homepage. I agree with rturbo, the faceballs is a ******* mess and is worthless for any real documentation or conversation.
Love those valve covers!
Here is the text so others don't have to scroll through FB: 240 AND 260Z R200 HANDLING PROBLEMS Its common for Datsun 240 and 260Z owners to replace their 3:36 or 3:54 geared R180 rear end units with a 3:90 geared R200 unit. Its a cheap and easy way to get a good ratio that works well with a 5 speed transmission swapped into those early chassis. But, the swap of an R200 in place of an R180 in the 240 and 260Z chassis produces handling problems. The handling problems are felt as: 1. On hard, drag strip type launches, the car consistently pulls to the left when the rear squats. 2. The rear doesn't take a set, constant steering correction is needed on right turns while racing on an autocross course or a track, and its difficult to put the power down on corner exit. The R200 is physically wider then the R180 and that width is asymetric - the R200 is wider on the driver's side of the vehicle then it is on the passenger side. This causes a suspension binding problem on the driver's side when the halfshaft bottoms (run out of travel). All the halfshafts used in the 240, 260, and 280Zs are basically the same, with differences on how the shafts are connected to the differential stub axles (center bolt yoke or four bolt flange). The fully compressed length of the halfshafts, as measured from yoke centerline to yoke centerline, is 12 3/16". The fully extended length of the halfshaft, measured the same way, is 14 3/8". This gives total travel of 2 3/16". I came up with these numbers after measuring four halfshafts, two with the four bolt flange and two with the ceter bolt yoke. In a R200 installtion, with the lower control arms about 7.5 degrees from parallel to the ground, the driver's side halfshaft's length is 12 3/8" while the passenger side halfshaft's length is 13 1/4". The driver's side halfshaft is almost bottomed out while this coil-over equipped 260Z is sitting at an unladen ride height of 6" at the rear. With the driver in the car and fuel on board, the driver's side halfshaft will be 1/8" from bottoming. Driver's side halfshaft almost fully compressed at static ride height. Passenger side halfshaft still has about 7/8" of travel before full compression At this point, the driver's side rear suspension will go into a bind with any compressive load and the spring rate will skyrocket to some number defined by the flexing of metal parts in the rear suspension and rear housing mounting. In addition, large stresses are being applied to the driver's side companion flange, stub axle, bearings, and bearing housing. These parts tend to fail more frequently in 240 and 260Zs equipped with a R200. How can the problem be fixed? 1. Disassemble the halfshafts and machine the outer to allow an additional 1" of compression travel. This is a difficult process mainly because the slip joint in the halfshaft is a bear to reassembly properly and the nylon spacers are NLA. 2. Make custom halfshafts of the proper length. This is a common fix and is done as part of a conversion to constant velocity joints. 3. Keep the static rear ride height at a point where the rear lower control arms still point down. I've had a few folks tell me that some 280Z halfshafts are shorter then the 240/260Z halfshafts. I've traded e-mails with 3 long time Z racers and all of them say the've never come across any shorter halfshafts that fit in the 240/260/280Z chassis. A couple Z parts hoarders that I know checked through their piles of halfshafts and were not able to locate any 240/260/280Z R180 or R200 halfshafts that were shorter. I think the idea of a shorter driver's side halfshaft for the R200 insalls in the 280Z is a myth.
'73 G-Nose 5.3/T-56 Work In Progress
tim.d replied to Domesticated's topic in Gen III & IV Chevy V8Z Tech Board
I may be calling you up for a windshield install referral in a bit! Looks great -
That'd be ideal!
Here's an online version that adds a little visualization too- http://www.rimsntires.com/specspro.jsp
- 2 replies
- Wheel size
- wheels
(and 3 more)
Tagged with:
Well at least you have polite friends
TrackZpeeds CXRacing LS1 T56 240z
tim.d replied to trackzpeed's topic in Gen III & IV Chevy V8Z Tech Board
"awww dammit Jim" hahahhahaaha -
In addition to drilling a -TINY- hole, it is sometimes possible to 'fill' the crack with an acrylic solvent glue. I have the same issue with my light covers, and will be attempting the repair this summer, using this: https://www.amazon.com/gp/product/B0149IG548/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 I've used it with success in other applications, but they haven't been in shaky environments.
Depends on the fans initially design orientation. 'push' fans will often be optimized for higher static pressure than a pull setup. That being said, the real world difference isn't probably that big... Adequate shrouds are probably the most important factor.
At least you've got most of the prep work done for yours! I still gotta pull mine out Also the MSA is a reboxed Tabco panel, it's a bit cheaper from tabco. Not sure about shipping cost differences though. https://tabcoparts.com/1234-42395.html
Exhaust routing out the back question or pics?
tim.d replied to JimCamp's topic in Gen III & IV Chevy V8Z Tech Board
Member cheesepocket has what I think is the cleanest center exhaust setup I've seen: http://forums.hybridz.org/topic/100304-new-exhaust-pics/ -
Woo! Another Charlotte/Raleigh V8Z! -
Tender + main springs on an S30?
tim.d replied to rundwark's topic in Brakes, Wheels, Suspension and Chassis
Great info chickenman! Thanks for sharing your setup- 25 replies
- suspension
- spring_rates
(and 4 more)
Tagged with:
240z S12W caliper/rotor rub!
tim.d replied to superduner's topic in Brakes, Wheels, Suspension and Chassis
This thread got me worried - I pulled my 240z S12w spacers from TTT out (still months away from installing), and they measure 20mm thick too. They're machined with 240Z engraving. So... bad batch? Incorrect Manufacturing? Wrong Rotor? Aliens? What's the donor car for the rotors you're using? -
The Z store = MSA. No Beuno. I've also seen bad things about the JPN Garage flares. JPN, MSA, etc are all very thin and don't hug the body lines the way nicer flares do... The only ones with consistently positive reviews have been from Classic Datsun - http://classicdatsun.com/new/240_glass.html And the MS ones that rturbo posted; those seem to be by far and away the most unanimously praised set. Check out this instagram account, he just finished his car with some MS flares: https://www.instagram.com/kevinnault/
Looks great! How many hours do you have in it?
