If you don't run relay's and just use switches, should you put a cap between the poles so that high amp drawing things don't damage the switch's contacts (like the fans)?
Also, I wouldn't run anything smaller then 0 gauge for the battery negative. I'd even run 0/0 instead. And I'd run it all the way to the engine block. This is probably more important for an EFI motor, but a starter motor uses a LOT of current.
On the gauge response, most of the time the gauges are dampened. In the miata world the stock oil pressure gauge sucks. What a lot of people do is put in a real sender (instead of a switch) then clean off as much of the grease on the gauge itself (which dampens the movement) to get the fast response.
I wouldn't be surprised if the same thing could be done to aftermarket gauges.
