Shift
Everything posted by Shift
  1. I'm no expert, but I believe that there will be an issue of adapting a RWD tran onto a FWD/AWD engine. Much like the issue with the FWD SR20 and The RWD sr20 trannies. Usually the truck/suv engines made in the late 80s threw the 90s were made in mexico and made with more leaniant quality standards, like the vg30's and the ka24's
  2. Isn't F&F4 suppose to be the "euro" version. IDK, i read it somewhere a while back.
  3. haha. I have a little honda Z50 also , except mine is in my honda monkey bike
  4. eh. neat. but I kinda got out of the whole pc case modding thing a while ago. "If iti doesn't do anything to make it run better, then why do it?"
  5. HD is dead, Long live blu-ray Well anyways. blu-ray has about a third more space than hd (like 54 gb opposed to 86gb, I could be wrong about amount of space). I think that was the main deciding factor in everbody going blu-ray. On the plus side. The Xbox 360 would be less prone to piracy if they produced games onto hd dvds
  6. Well I guess being patient is a good thing. Most people that paint by themselves tend to get impatient (myself included, and I'm no body guy). Plenty of resources here, just have to search.
  7. you go cheaper, doing it yourself going the rustoleoum route.
  8. You can make a vac forming rig from a couple old toasters. a bench some wood and a shopvac. For the forms. you can shape the approximate shape with foam then cover and shape with bondo. cheap and easy, and the bondo make a smooth enough surface to help keep the acrylic clear.
  9. Great job. How's it drive with the front all tubed? Hows the temps with that hood?
  10. Let me suggest shrink tubing instead of electrical tape. In the long run you will be greatful. The adhesive on the tape, after a while comes off onto the wires and makes a great mess of things.
  11. cheap starter usually = crappy starter. I just rebuild mine, myself using a starter from an auto. (not interchangeable parts, inless you use a little red-neck ingenuity)
  12. And didn't they make a concept of the new tiburon? They say its suppose to have 500hp and is going to be made to compete with the mustang. Looks ugly though
  13. Search. I recall it being done 3x. none of which the details were revealed in.
  14. I think you can do it with a pair of 240sx ABS components and a pair of "arduino" boards. It uses pulse width modulation, I assuming. It can trigger when the pared boards compare wheel rotations of the front wheels and and if it goes too far out of a set ratio, then it tell the EMC to back off on the throttle. The problem would be having the boards to talk to the EMC. I think that MS would have the best compatibility. Maybe a third on the drive line somewhere for a "estimated" rear wheel spin reading.
  15. if its so empty all the time, park lengthwise
  16. unscrew the valves from there tires and tape them to there windshield and leave. that what i do especially if they ding my car or are crazy close.
  17. I love that show. I never know when its on though
  18. baking soda. May take longer to blast, but leaves a better finish and to clean you just rinse in some water or a solvent.
  19. starter motor clutch flywheel preasure plate bellhousing throwout bearing trans mount
  20. Would this work for a r180 diff for A 260Z? http://cgi.ebay.com/NISMO-2way-R180-LSD-200sx-S14-S13-240sx-Ca18DET-SR20DET_W0QQitemZ230210509948QQihZ013QQcategoryZ72205QQrdZ1QQssPageNameZWD2VQQcmdZViewItem?_trksid=p1638.m122
  21. wet felt works better at holding up the resin. just need to be sure to wait till its thoroughly dry
  22. Shift
    My car.
    Car looks crooked. Was it in a front end collision at some point?
  23. Isn't that civic the one that they cannibalized a v8 rx7 and dropped the civic body onto the chassis.
