jeffer949
    4
Everything posted by jeffer949
  1. I have a few but they need to be over bored. Is that something that interests you?
  2. Something is off on that dyno sheet. The torque and Hp dont cross at 5252. It mathematically has to cross there so I'm not sure what is wrong with the dyno chart or the dyno.
  3. I like where this is going. Im just curious if we are going about this the wrong way. Instead of us modifying it. Why dont we contact the vendor. The changes needed wouldn't add to the production costs any or if there is an increase, it would be small. The company is already set up to make these efficiently and the hard part is the splines which wouldn't change. The rest is just a different profile to make it suite our needs. I'm sure someone on here would draw it up. Seems the simpler way to go...
  4. Umm why do you need head studs and MLS head gasket for 250 HP? The only thing the MLS is going to get you at that HP levels is broken ring lands or bent rods instead of just a blown head gasket when the engine detonates.
  5. Run stock rods. You don't need any more for your HP goals
  6. Mike, Its been an honor to watch your journey. Sometimes enough is enough though and we understand. I wish you luck in everything.
  7. Agreed. And you can fit the factory A/C from a 280z in them also.
  8. I don't know what my machinist set mine to but I know that it isn't an interference fit and slides right together.
  9. Hey Mack, Did you ever get your cams reground and installed? After a few major delays getting my heads rebuilt and MAJOR miscommunication from Motorsport on my cams I ordered. My engine is finally going back together this weekend. I went with MSA's stage one cams which are just under the 131H grind you went with on lift. Just curious how you are liking them and if you noticed any power increase and/or fuel mileage increase.
  10. HAHAHAHA 200 bucks for a that? This is an old trick people have been doing for years. http://atlanticz.ca/zclub/techtips/tempsensorpot/index.html
  11. Why does the guy reporting this to us have 0 posts? Not doubting its true just seems odd
  12. I personally would rub it with some emery paper to take off any rough edges and run it.
  13. http://hokeperformance.squarespace.com/store/vq-swap-shifter-mount
  14. I personally would take the housing off and take it to a welder/machinist. My father in law does this kind of repair pretty often. He will weld it up and then re-machine the bore back to round.
  15. Didnt you fix your dash years ago? Did it not hold up?
  16. ACT sprung 6 puck with the heavy duty pressure plate. It's held up to hard launches and has held up well.
  17. HJC is not Chinese. They are Korean or Taiwanese i believe. Ok helmet for the money. One thing you need to look at is the standards required required by the sanctioning body your racing in. Pretty much all Manufactures are going to make different levels of helmets that meet different requirements. HJC for instance has entry level helmets at around $80 retail. And they have the Rpha Max helmets also which can be in the $400-$600 range. The cheap ones are only going to be DOT. They will have mid level ones which are Snell also but typically the cheap ones that are snell are very heavy as they have to use heavier cheaper materials to get the strength. Their top of the line helmets which are also snell but are still light do so by using more expensive lighter weight materials. So make sure you do your homework on what is needed and approved for the events your going to be entered. I come from the motorcycle world and worked at dealerships for many years and sold hundreds of helmets. Personally the only 2 brands I will wear is Aria and Shoei. Shoei being my favorite. I race motocross and do some street riding. I have a shelf full of helmets that I have wrecked in hard and then put on the shelf because one good impact is all they are intended for. Yes its expensive but what is your head worth? Also make sure it fits. Have someone measure your head and go by the manufactures size chart. Also under stand that different helmets have different head shapes. Just because your uncomfortable in a helmet that is sized right but isnt comfortable because it is the wrong shape doesnt mean you try the next size up. I have a long oval head and many helmets dont fit me well due to that they are more of an intermediate oval shaped. Ok Done ranting. Not sure if that helps any but a good fitting helmet is more crucial than buying the most expensive in my opinon. Keep in mind when trying them on that it is the tightest its going to be in the showroom and it will loosen up.
  18. My frontier's heads are off right now also!!! You didn't say what year but if it has a knock sensor I would go ahead and replace it with new one. They are known for going out and you have to remove the whole intake to replace it. As far as cams go I'm not sure but would there be a need to retune the ECU? and do you think there would be a decrease in fuel consumption during highway cruising?
  19. I have them... But they are in the car. LOL and I doubt your willing to pay for coil overs in order to get them.
  20. Guys I'm here. Didnt scam anybody. Just never saw the notification that I had a message. When my daughter gets on my tablet and hybridz is open and then she closes the window the red notification doesnt show back up when i get on. The part is sent over a weekago though.
  21. So my uncle, my dad and myself where going through my grandpas garage last weekend as they are getting the house ready for sale as they are in a retirement home now. So we are cleaning and divining up tools and what not and my dad pulls a box down from the rafters filled with old gaskets. Some from his jet boat he built in high school and many from his Z's back in the 70's when he had a new 260 and a few 280's. The gasket that has me curious is an asbestos intake/exhaust gasket with some metal reinforcement on the intake I believe, Maybe it was the exhaust I'm not sure. I know the health concerns related to it and if it was broken down at all I wouldn't consider it at all but its in perfect shape. I've always had issues with exhaust leaks on my turbo manifold with felpro gaskets. I guess my question is would you use it or just toss it because of the material?
  22. Unless your wanting to spend a bunch of money just buy ones from a parts store. They aren't that special. Now if you do alot of valve adjustments like I do and get fed up with fanning out the feeler gauges to find the right size you buy a set like this. They come in a vinyl pouch and each one has its own spot. Much faster. But alot of money to adjust the valves on your L6 every few years. http://www.ebay.com/itm/5XU51-Feeler-Gage-Set-20-PC-/381017937215?hash=item58b670553f:g:HwkAAOSwxp9W2O4Y
  23. I have one. Not sure how shipping would pan out. But we could look into it.
  24. I feel like I remember hearing something about xtd clutches being physically bigger or thicker than lets say an ACT. Anybody else hear anything like that? If so a different clutch could solve the issue.
