12
Everything posted by rossman
Yah, it's a very informative thread. About half way down it tells you how to select lash pad thickness on a budget - with a standard aftermarket lash pad (flat bottom) and small pieces of feeler gauge.
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
Check out this thread:
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
Thanks for sharing! You asked for comments so here are a few.... Who is your intended audience? Novices? If so, I would recommend covering more of the basics. Like setting up from the beginning. I the first video what you are really doing is verifying the cam wipe pattern after you installed the correct lash pad. Was it just blind luck that you got the correct lash pad the first time? How did you pick the lash pads you are using? You should address that in your video to be helpful in "lash pad sizing."
- 9 replies
- l28
- degreeing cam
(and 2 more)
Tagged with:
You might have better luck asking stock zcar questions on www.classiczcars.com. That forum is geared more towards stock cars. Why not purchase a used one and have it rebuilt? Better yet, rebuild it yourself. I know there is at least one rebuild documented on this site. Most of us on HZ would look for a more modern upgrade that can handle additional power. And on that note, a 240sx gearbox is an easy upgrade. I went with a z32 gearbox but that requires an adapter plate and machining of the bell housing. 350z, CD09 6 spd is a great one too and you can still buy the kits.
broken stud, then extractor...can't remove reminisce
rossman replied to scartail's topic in Trouble Shooting / General Engine
Pull the head and take it to a machine shop to remove and helicoil it. Sometimes there's no way to get around it. -
Wow, very nice!
I can't answer your question about spring seat pressure but you didn't say anything about what rocker you're using. Do not use re-ground/surfaced rockers. Use only new Nissan OEM rockers. I would use both a drilled cam and spray bar with a high volume pump. Lucas makes a good ZDDP additive or just go with a good racing oil like Brad Penn with zinc already blended in.
A recent photo of the engine. It needs a lot of clean-up, wire tucking, etc. but it runs and drives reasonably well given my novice tuning abilities. I need to fix a few things that are bugging me before I get it professionally tuned like reasonably sized catch cans and a better IAC solution. The current IAC setup works ok at idle but turns into is a leak when the turbo spools up, slowing boost response.
ANOTHER Datsun Z/LS3/T56 Swap Thread
rossman replied to Ironhead's topic in S30 Series - 240z, 260z, 280z
Looks great! -
I answered your question in your other thread: FYI, it's easy to find answers to your questions, as they have been asked and answered hundreds of times the the past. In a Google search type in the following. 1983 280zx crank sensor site:hybridz.org The key is following your search terms with "site:hybridz.org" to restrict the search to Hybridz.org. Good luck and happy searching!
It has a sensor located in the distributor. I would install the fuel management system that you or your tuner are most familiar with.
It would be useful to post up the year of the car and whether it is stock or not. Assuming it's stock, there are significant differences between late and early 280z models and each have common problems. Also, tell us about the current situation so we can help diagnose.... Did you verify that the injectors are not getting 12v while cranking? Was it running previously and just suddenly stop? Has the car been sitting for a long time? Have you done an in depth search of this site. The best way I have found to do it is to use your friend Google: "stock injectors not firing site:hybridz.org" In a Google search follow your search terms with "site:hybridz.org" and it will focus on this site.
I love the stainless surrounds around the tips. Did you custom make those? -
Congrats! Sounds like it's a pretty well sorted car! How well did it hold up to the other cars? I love the e30, my favorite beemer.
simplicity and reliability, ZX turbo track toy
rossman replied to stupid_fast's topic in S130 Series - 280ZX
Great thread and keep it coming! I went to my first drift event, Lone Star Drift this past Saturday with my 16 yo son. We had a great time. I was surprised how many Zs were there. There were mostly 350z, but there were a few S130 and Z31s in the mix. -
Why would you ship that from America? A 2+2 story
rossman replied to Villeman's topic in S30 Series - 240z, 260z, 280z
Congrats! The car looks great! -
Been driving the car around a bit. I finally got the idle tuned good enough the it doesn't die every time I let off the throttle, lol! Does anybody know of a good resource for tuning "modern" efi, specifically a system similar to Wolf v500? Seems like Haltec is similar since the owners of both companies used to be partners at Haltech, at least that's what I remember from internet folklore.
It's a beauty! It's probably the most tastefully modded cars I've ever seen seen. Well done sir!
+1! Very impressive indeed! -
This my friend is how we learn I've made many and I'm sure, despite my best efforts will continue to do so. I have the same setup but haven't noticed a dead zone, but it was about 10 years ago when I installed the zx master cylinder and I don't recall what I did regarding the push rod. I'll take note next time I drive the car. I DID make the mistake of keeping the 7" brake booster. It takes quite a bit of force on the petal to stop the car quickly. Should have upgraded while I was at it... Cheers, Ross
Stainless steel headers, exhaust and JDM twin-pipe rear muffler
rossman replied to SeanD's topic in Vendor's Forum
Very nice! -
RWB Jeff - 1970 Datsun 240z - Build
rossman replied to 240zJJR's topic in S30 Series - 240z, 260z, 280z
Love the attention to detail! I will be doing this someday too. Right now I'm running the dim as hell stock lights. -
Thanks! I can't remember if I listed out all the mods I've done over the past 3.5 years, but here they are: 1) Baddog floor pans and frame rails 2) zfever aluminum fuel tank 3) relocated fuel pump 4) Techno Toy Tuning rear LCAs 5) Custom (HZ group buy) rear Wilwood Arizona Zcar Rear disk setup) with Wilwood parking brake calipers and custom parking brake cable 6) S2k seats with custom seat mounts 7) Six additional Speedhut 2-5/8" Revolution gauges, now 8 total including speedo and tach 8. New replacement vinyl kit. Purchased an MSA full carpet kit but didn't like the quality. 9. Removed the rear bumper to straighten but realized it's too far gone. 10. Rewired the fuel system, mounted to the firewall now (instead of a cutting board 😄) 11. Removed the PCV plumbing that was choking off the block vent. Simple k&n filters now but will replace with proper catch cans soon 12. Had the cam repolished by isky and installed new Nissan rockers and lash pads. The previously installed, resurfaced rockers started spalling. 13. New battery 14. Vintage Air AC because Houston. Tired of sweaty back 😅 15. New Rota 16 inch wheels to fit over my new rear parking brake calipers - now with proper offset 16. Replaced 6 puck sintered iron clutch disk with an organic. I think it may already be slipping 😣 18. Replaced the passenger side axle CV shaft boot. I believe the stock lca was hitting it. 19. Installed new Techno Toy Tuning mustache bar. I believe the 280z one I had previously was allowing the diff to rotate enough to allow the cv axle boot to contact the rear lca. 20. I'm sure there is more, but that's all I can remember! On the short list... 1. Proper catch cans 2. "Racing" side mirror fix. Both flop around...worse now that I tried to simply tighten the ball clamp down 3. Four wheel alignment 4. New shifter in inner bellows using Miata bellows. 5. Dynamat 6. Actually install vinyl and carpet 7. It never ends! 😁 Thanks for looking!
