cgsheen
    9
Everything posted by cgsheen
  1. +1 Patricks 260Z was hit by a Silverado. There's a bit of room behind the rear quarter. I was able to hammer it out and get it close enough all it took was a skim of glaze to get this corner back.
  2. That's weak... Die grinder?? This isn't something new - early Z's have a large front hub. You can fit anything on the rears but the fronts can be a problem for modern spacers and wheels. Super disappointed that Zcardepot would screw you over like that... Sakura Garage - Tempe, AZ
  3. Ding, ding, ding. On the L28ET the bypass is in the sandwich plate for the oil cooler and the block is plugged.
  4. The L28ET ECCS harness (engine harness) is pretty much self-contained. You won't need any of it for an L24 setup. You won't be using the turbo coil and ignitor - there may be some wiring there to be removed also. There will be some relays that they would have to add and wiring connections into the 240Z harness(es) that you will no longer need. Anything that ties to the ECCS harness can be disconnected and removed. Getting the stock harnesses back to normal will entirely depend on how they did the turbo swap and if they eliminated any of the stock wiring when they did it. If you're not familiar with stock 240Z wiring, that may be difficult to know what - if anything - they changed or removed. Good thing is: 240Z engine wiring is pretty simple. Alternator may be something to look at. If they switched over to the internally regulated alternator that would be stock on the L28ET, you may want to just stick with that rather than going back to a stock 240Z alternator... BTW, I'll take your turbo engine ...
  5. Refer to the 1972 240Z Factory Service Manual. Emissions Control section - page 2. l24emissions.xps
  6. This picture is of a "late" clutch pedal - used in a 260Z and 280Z. The 240Z clutch pedal was different - made of thinner steel and curved along it's length to add strength. At some point (1973ish...) the brake booster was changed and a larger booster was used. The clutch master was moved farther away from the brake master due to the larger diameter of the new booster. The pedal box and clutch pedal changed also. Looks like you need an actual 240Z clutch pedal.
  7. Is your engine missing as well? (as badly as the Tach is jumping around?) The blue wire from the electronic ignition module is the "signal to fire" to the coil. If the electronic ignition module was faulty in that way, I'd expect the spark from the coil to be erratic as well. If the Tach is known to be good and the engine runs smoothly, I'd suspect the wiring / connections between the electronic ignition and the tach. It wouldn't be that difficult to run entirely new wiring from the electronic ignition module to both the coil and the Tach - it's a simple circuit.
  8. ?? A glass shop should be able to get you a new windshield. Any glass guy here in Phoenix can get one next day ("from the warehouse"). Same should be true in the Bay Area. Sometimes the sticking point is the gasket - and the young guys at the shop don't know anything except how to glue a windshield in. But, even if you don't want them to install the windshield, they still should be able to get the glass...
  9. Oh my... I haven't bumped this in over a year. Yes Dorothy, Sakura Garage still sells Stance USA coilovers for the S30!
  10. Eventually it will be important that those sensors are working properly. You'll be able to buy a new CHTS and replace if necessary. The intake air temp sensor in the AFM might be a different story... It's sounding more like timing.
  11. If you're getting spark, the ECU is getting RPM information from the CAS. DON'T touch the AFM internals (although in reality, it would be unusual if someone hasn't already...) Do make sure the AFM electrical connections are clean and have continuity back to the ECU. However, I'd say if you have spark and fuel - better check timing... The 310's are going to make that engine run rich. Make sure your spark plugs are clean (new preferably). Start from the beginning and check the mechanical timing. You can't make any assumptions with these old engines - you don't know whose hands have been on them. Having said that, 90% of the problems with these early EFI (ECCS) engines are ELECTRICAL in nature. Make sure your sensors and associated wiring are working properly, have CLEAN and deoxidized connections, and that their wiring has continuity back to the ECU. Be sure you have the Factory Service Manual for 1981 with the Turbo Supplement (not a mistake, the L28ET with crank mounted CAS came in the 1981 280ZX Turbo model) and follow the trouble-shooting steps. There's a section that shows how to do all that without the "Analyzer". You just need a multimeter.
  12. Stock, the Tach is receiving it's signal from the electronic ignition module - under the glove box area. The electronic ignition runs a blue wire to the "-" post of the coil (to fire the coil) AND to the Tach through a resistor. The blue wire tees off under the dash. You'll find the resistor (a small rectangular plastic thing) coming out of the dash harness near the glove box. The stock electronic ignition module should be removed if you're not using it - at a minimum, the blue wire should be disconnected from it if you're using the blue to drive the Tach.
  13. Well, you probably know by now my suggestion: Don't waste any more time or money on the stock ECCS... Having said that: you can plug an '83 ECU in to test and it'll work. If you're going to run it long-term, remove the dropping resistors and jumper them out. They're arranged 4 resistors in one pack, 2 in the other. Each pack has a +12V "in" wire and then "outs" to the injectors. All the injectors are powered from the same source - all that matters is that you get all the 6 "out to injector" wires tied back to the voltage source wire(s). Whatever problem you're having, is likely NOT the ECU. It's likely wiring/connectors/harness/someonescrewedwiththeafmwhentheyshouldn'thave/and etc... There is also no "advantage" to using an '82-'83 ECU on that engine that would justify the change - or cost. Put your time and money into a new harness and a better engine management system - at very least a new harness (with a better engine management system). That L28ET deserves it...
  14. Nice camber plates. Dang, mines not going to be the only gold Z in the SW... If you ever have that thing in Phoenix, be sure to stop by.
  15. If the CAS was dead, you'd have no tach input (engine RPM information) into the ECU - so, no RPM information in the software. If it was sporadic, you'd have a sporadic RPM reading (and (should have) sporadic spark). Those optical modules were found in every Nissan of the period - don't need to search for a Z31 Turbo CAS... But I doubt that's your problem.
  16. The stock FPR should maintain an approximately 36 PSI pressure differential between fuel pressure and manifold pressure. So, higher pressure with vacuum is wrong - fuel pressure at the rail should drop corresponding to the amount of vacuum (10 PSI vacuum (-10 PSI) should equal ~26 PSI fuel). Higher fuel pressure with boost is correct - add the boost amount to 36.
  17. Very interested to see how well this holds up. Let us know how it fares over the summer and if any cracks re-appear. The sun is really tough on dashes here in Arizona...
  18. A. I can't believe you welded the striker to the frame... B. I can't believe that you didn't take the entire latch mechanism out of the door and completely clean and lubricate it. (Well, I can believe that... It's a pain...) IMO you're looking in the wrong place for the solution to your problem. Do what Miles said above and make sure all the parts inside the door are adjusted and working properly. But, my bet is that the entire rotating latch assembly needs to be thoroughly cleaned, lubricated, checked for wear and proper operation.
  19. I still have the L26 that was in my 260Z frame when I bought it. A mechanic at the other end of the building ends up needing a head for a 260Z he has in his shop. I took him my head, he had it thoroughly checked out by our local machinist. The head is good, so he wants to use it for his customer. He doesn't know what it's worth - I don't know what it's worth... I want to be fair with this guy and his customer. I've looked on the interweb - eBay mostly - and there's not a whole lot of info... Help a brother out? What do you think I should be getting for a used E88 head?
  20. NewZed is also right about the 280ZX community at Zcar.com. And about the fact that many here (including me) will just look at your car as a carrier for that L28ET...
  21. The harness runs down to the floor on the right side, over the seat mount, then into the quarter through a big hole just behind the door. That hole has a grommet. It goes back into the abyss - over the wheel well then down in front of the evap canister and to the floor. (it can be difficult to fish the harness through this space...) Somewhere around there (before there) the dome light and rear window defrost take off. The rear-end wiring goes down to the deck in the quarter and back to the rear. It comes through a smallish hole to the right of the tails and across the back of the car to the left for the lights and then continues on to the speaker and antenna. Near the evap canister, the wiring to the fuel tank goes down through a hole with a grommet. Everywhere the harness passes through sheet metal there should be a grommet...
  22. Still using a single coil for spark? No one is going to know the answer to your question without knowing the particulars of your "standalone". The 260Z Tach works off the "pulse" that causes the coil to fire (you'll notice that the blue "tach signal" wire is connected to the "-" coil post and the output of the electronic ignition module through an inline resistor in the stock configuration).
  23. Well, the spare tire well is sprayed blue metallic... If you're after the original factory color, look under the weatherstrip, or at the overspray under the dash, carpet, vinyl... Then, the factory colors for various years are fairly well documented on the interweb.
  24. In my 260Z FSM that frame dimension drawing shows the datum line you're referencing to be the center of the hole in the compression rod mount - not the "back" of the mount. That may mean you're farther away from stock than you think.
