68
Why did I think we were talking 280ZX? Sorry about that. Looks like a 280Z, there isn't enough room to move the strut back very far before the spring hits sheet metal, maybe an inch. You could cut the whole strut tower off of the upper frame rail and move it back, but that's a hell of a big job, and you better tie it all together well because it's a highly loaded part of the chassis. It's a lot easier just to run an adjustable TC rod. You can completely solve the LCA binding problem by running monoballs or rod ends on the front LCA. The next issue is that the tire will hit the front fenders or the airdam if you have one. Can trim for clearance. I haven't looked at it for a long time, but I seem to recall people getting into the 8 degrees range on race cars with adjustable TCs, and 5 degrees is easy. Caster made a huge difference on my Z, one of the best mods I did back when I was daily driving and autoxing every month.
If you go to coilovers you can run a much smaller 2.5 ID spring, and then you can move the strut top back within the existing tower. This is not something we can do with the S30, but the S130 has much bigger strut tops, so more room to play. They do it all the time on Mustangs, so it's a known solution. I haven't seen a double adjustable plate for a 280ZX, but anything that has the adjustments and is generic enough should work. Might be able to just use the Mustang parts, just need adapter bushings to fit whatever struts you're running: https://www.maximummotorsports.com/Mustang-Caster-Camber-Plates-1990-1993-P254.aspx Could probably use these 510 plates from DP and cut the hole to the rear to add caster if you prefer: https://www.dpracing.co/datsun-510-front-suspension-1
Underwhelming Lap Times
JMortensen replied to Twisted46's topic in Brakes, Wheels, Suspension and Chassis
Going to require a different filler tube though. If the 260 filler tube is available it would probably go in easier, I'm guessing. -
https://www.ebay.com.au/itm/1955-1956-1957-CHEVY-GAS-TANK-FILLER-NECK-CHECK-VALVE-KIT-USA-MADE/133336309996?hash=item1f0b76a0ec:g:IxgAAOSwcB1eSbM0&frcectupt=true This ebay listing is from Australia, but says the product is made in USA. -
I wonder if you could use a simple flap under the cap, like they do on fuel cells. I haven't seen a one way valve in the filler neck, if that exists that would be another option. I guess the filler hoses are all getting rock hard at this point. 20 years ago I had to remove my original with a hammer and chisel. LOL If you can still get a new one could measure and see if there is a one way valve for a 2.5" or 3" or whatever diameter hose it is. -
Richard's offhand mention got my wheels turning too. DCT looks doable for about $5K all in...
That noise was entirely 3rd gear related? Seemed to be happening regardless of gear. I had a similar one on my car, could only hear on decel. Turned out my driveshaft AND CV bolts had loosened. I safety wired the CVs and double nutted the driveshaft and haven't heard it since, but I'm just autocrossing, so not nearly as much chance to hear things like that. Can you add more hood vents? Under hood air looks like a problem for you. 167 mph on Conrod. Very impressive, and agree with Richard, nice job resisting the lift at the kink! In the sim-racing world, it's a toss up for me between Nordschleife and Bathurst for me. My two favorites. Hope to some day get there and drive something, probably a rental Kia around it. Inspiring stuff, thanks for sharing.
There is quite a bit of weight in the tubes. When I did mine the SCCA said they were going to change the tubing requirements, and at the time they had 1.5 x .120 and 1.75 x .090. I went with 1.75 x .120 anticipating a change to a heavier tube, but when they released the rules, they had gone the other way and the requirement was 1.5 x .095. I haven't gone through how much weight I would have saved with 1.5 x .095, but man, I wish I had gone that way. Probably 50 lbs added, a lot of it way up high. Not good. EDIT--I did do the 6 point main part of the cage in 1.75 x .120, then I did all of the other stiffening tubes in 1.625 x .065.
I'm not a vintage racer, but I believe they're allowed to run the way they were in the past. They used to allow cages without the tubes welded all the way around too, and I think those cars are still allowed. BTW I did the same on the seat mount, welded to the SFCs. Used to be a video of a Honda drag racer that went sideways into the wall and the AL seat folded in half, video was pretty scary looking. I get that some seats don't need it, but I like the idea regardless of whether it's required.
Have you seen the Flying Miata butterfly brace? That's a good place to start. Hard to do on a Z with the exhaust hanging down. Reason number 486 for going with sidepipes. If I ever get around to doing a paneled floor, I'll incorporate some sort of bracing into the top side. For protecting the driver really needs to extend all the way to the rockers.
Yeah, haven't seen a racing series where AL tubing is allowed. Mostly it's mild steel ERW (drag racing) or DOM (SCCA). Some allow chromoly, but it's harder to weld correctly so you have to be more careful with it and the tech inspectors will scrutinize it more closely. Re: Pike's Peak, the one thing that I think it's really hard to do on a Z is to protect the floor. It's already so low, and most of us want the car lower, that it's tough to get any protection on the floor. Heavy85 was talking about how to do it when he rolled his Z at a hillclimb into small boulders, luckily he walked away unscathed.
1976 280Z RB30/25 (R.I.P.S.)
JMortensen replied to artishard116's topic in S30 Series - 240z, 260z, 280z
Looks a lot like mine, right down to the defunct Autopower mounting holes in the rear fenderwells! Nicely done! -
Wouldn't it be nice to see some actual testing? There are some basic ideas of how to do such a test in the book Think Fast, but requires making plates to bolt to the hubs and screwing to the slab. I suspect I could have gotten the rigidity gains I did with fewer tubes and less weight with some FEA prior to building too. All too technical for my little brain...
I stitch welded those areas. The middle of the wheelwell is easy if you have a rotisserie. The inside area where the wheel well hits the inside of the body is a huge PITA, because there are about 4 layers of metal with seam sealer jammed in between. I'd either skip it, or weld a plate that attaches to each side over the seam so that you don't have to dig all the sealer out. Took forever.
Just FYI, I've got an L33 aluminum block 5.3 with a small cam and carb setup because I can't wire a lamp and it should put down 370whp, so that's mid 400s at the crank. It's not hard to get power from the LS. It's glorious, runs on pump gas, not high strung like my previous L28 with triple 44s and 11:1 and all that stuff. Torque out of low speed corners is amazing. On the tank, I would suggest NOT doing a fuel cell. I had similar issues with leaks, I think my tank split the seam or something. Wasn't rusty, never had issues with rust in the lines or any of that, but WOULD NOT seal after replacing everything, also never could seal the cap either so I'd always have fuel leaking out around the door from tight left handers. A cell did solve that problem but it was expensive, added about 20 or 25 lbs (friggin heavy), and was a serious PITA to install correctly with a barrier between the cabin and the cell itself, something most people don't do. Surge tank is pretty easy to DIY. Have been thinking about FI for mine, and looking at options. There are a lot of AL catch cans out there with NPT fittings, would be pretty easy to set one up with some AN fittings, set up an inline pump for the FI and run the return plumbing back to the tank. If you have a tig would also be easy to make, just get a short length of tube, weld caps and AN fittings to it. -
Settling on two rear end options...
JMortensen replied to AydinZ71's topic in S30 Series - 240z, 260z, 280z
From most aggressive to least, options that are actually available for R200s: welded, clutch, helical, viscous, phantom grip. -
Like the old Phantom Grip but with a trap beat on the videos instead of Freedom Rock. Shit product. -
Do I Need Bump Stops With New KYB's?
JMortensen replied to Mayolives's topic in Brakes, Wheels, Suspension and Chassis
Yes, they really are. What do you have to do? Lower the car I guess. I used to hit them quite a bit. CA roads didn't help. Now I have sectioned struts and 600 in/lb springs, so not an issue anymore. -
The problem with a deep 1st gear and low gears is you wind it out at 25 mph. That's why you have 3.54s in the 280. When you go to the taller 3.062:1 1st gear in 1980 they also went to 3.90 diff gears.
Slot direction doesn't matter, but people tend to do it the same direction as the fins.
It's just like a squirrel cage fan. So if you look at the fins from the top of the rotor they should point to the back of the car.
There are straight vaned rotors and curved vane rotors. My guess is that Dave is selling the straight vaned type, which are not directional. If the actual part number shows curved vanes and Dave is saying that they're universal, that would surprise me.
Any circle track supplier will have rotors. You need to know the diameter, the thickness, and the bolt circle. I think their normal kit is 12.2 x 1.2 with a 8 on 7" bolt circle in the front. Not sure if they use the narrower .83" rear rotor. Think so. Pit Stop USA usually has pretty good prices. There are different brands, but I linked to their Wilwood rotors here: https://pitstopusa.com/c-135208-brake-systems-and-components-disc-brake-rotors-wilwood-rotors-wilwoodcurved-vane-brake-rotors.html
Apex Engineered: My evolving experience
JMortensen replied to BoulderCharles's topic in Non Tech Board
I tried to offer a full chromoly 930 CV axle kit for the R200 when I had M2 Differentials up and running. I never took money for it, but trying to get the ******* machinist to make the parts was positively infuriating, and it went on for months. All I can tell you is that it's just as irritating for Ohm as it is for all of you. I felt like I was going to get an ulcer trying to get that kit together, finally just gave up on it entirely. Not making excuses though, and Ohm shouldn't have taken any money until he was sure he could provide the parts, but I really do feel bad for him, having been in a similar situation. -
Not a fan of the roof spoiler. Surprisingly not offended by the rest of it. Pretty impressed actually. I can see the modded ones looking really good.
