Thanks for that oil information, I should be able to put that to use. This weekend I turned the engine over with the valve cover off to check compression. It measures even across all cylinders with number 2 with the bad lobe about 5 psi lower than the rest. However, the compression numbers are uniformly low; typically I will get 110 to 115 psi, at least on a good stock L28ET with stock turbo cam. With this cam, I got 90 psi on all but number 2 at 85 psi. Oh well, I'm not tearing into the bottom end, it is what it is.
While cranking the engine with the starter with the plugs removed, the oil flow on the cam seemed good, it didn't squirt but pooled out of the cam holes and number two intake did not seem lower than the rest. But the fact that the oil is quite dark (fresh change before the spring track event with no driving since) tells me the top end seriously overheated. Of course I have not yet checked the level, it's possible it's low and that would explain everything.
I just wanted to confirm with those suggesting a spray bar in addition to internal cam oiling, all that is necessary is to swap the earlier cam towers and spraybar. Is there any machine work to do on the cam towers to retain the internal oiling, or are those passages already present?
Thanks again,
Nathan
Edit: Checked the oil level, exactly one quart down on the stick. Could that, and a day on the track, cause starvation on the top end? Obviously it had something to do with it, but is it soley responsible? I'm still trying to make up my mind whether to add oil spray to the cam or to dig deeper for another issue ...
