NewZed
72
Everything posted by NewZed
I did miss the title pieces. Best to list things out, for me anyway. You didn't mention the bushings. With factory rubber bushings, the caps need to be torqued with the car down, and rolled to unbind the tire/ground contact, and at ride height. If you torque them with the suspension hanging the rubber will hold the car up.
The lift under the crossmember hasn't been released. It hasn't been rolled to unbind the suspension after lifting. That guy in the picture is very strong and is pulling up on something. You have low profile tires, creating a bigger gap. You installed too-tall springs. There's a few clues. You haven't really given any info about the parts. Springs, isolators, perches...every car has those.
Never mind. You have the signs of a difficult customer.
You're dumbing down a lot of detailed information. "930" is a CV design, with a variety of materials used and manufacturers involved. They're not all the same. "Q45" is a car not a diff. The Q45 came with the short-nose R200, not the R230. The R230 came on twin-turbo Z's and SUV's. "Chromoly" is an over-used word that actually means very little. You can have a "chromoly" axle that will twist like a pretzel if it hasn't had the proper heat treatment. Seems like you haven't really absorbed much of what people have been offering. Look through the nicoclub FSM's to learn about the diff options. If you're not careful you'll buy an R230 kit, for a Q45 short-nose diff, with a 3.13 gear ratio. Not good.
Body Electrical has a clear schematic. I'd post a page number but you didn't post a year.
Early 280Z, late 280Z, or 280ZX? They all use a different EFI relay. If you studied the wiring diagram you'd probably realize that you can work around it. Half of the early Z relay is the fuel pump relay.
If your cooling system is properly filled, how can it accept two quarts more of oil? Have you drained a quart or more of oil from the overflow bottle? Just trying to help you with some details. If you just have a trace of oil in the coolant, and you're losing quarts from the engine, why are there not quarts of oil in the cooling system? Where did it go? You might just be running more oil through the combustion chambers. Worn rings maybe. You'll still be removing the head, among other things, but might be better prepared to fix it.
Probably depends on how you use the 500+ HP. Drifting? The viscous diffs don't seem to last long. Drag-racing? Probably depends on how well the car is set up. Autocross/road-racing? Some people say the viscous diff isn't smooth, just due to the way it works. Not your question but might be relevant. And the 180, 200, and 230 numbers are just the size of the ring gear, which is relevant to ultimate load-bearing capacity but might not be the most important factor in-use. Then there's the size of the external case, which you're talking about here, but may not be relevant. Haven't seen any broken differential housings reported in the R series. Don't forget the number of pinon shafts in the diff itself. Two versus four. They affect durability. Don't overlook the mounting problems with the short nose either. They can exacerbate the half-shaft problems. Misalignment of the shafts under load, from the diff moving, will find the weak spot in a drive shaft. Read through Sunny Z's thread about the path the to the 8.8" Ford diff. He's your role model. He's already done 3/4 of what you're worried about. http://forums.hybridz.org/topic/95937-78-datsun-280z-53-build/ http://forums.hybridz.org/topic/109324-ford-88-irs-conversion/
Metric, US/short, or Imperial/British/long? And, of course, you're talking fractional measurements, like .00003 tons. There are better units of measure out there. Losing not loosing. Unless it's spraying around the engine bay.
Carb to manifold adapters are common. Might be easier and just as effective as building a new manifold. Identify a common carburetor that's appropriate for the engine and build an adapter to your current manifold, or a stock 240Z manifold. What is a "Customs mexican madera" manifold?
The drums are probably worth something to someone. $20 each? I have my own spare set. Pre-77 wheel cylinders are about $50 at the parts stores. Calipers are good for cores. Rotors - depends on condition. Hawk pads - pro-rate to wear. Your thread title can't be much more uninteresting. Probably very few people even looked at it.
Need some opinions on rear half shaft route with R200 VLSD
NewZed replied to seattlejester's topic in Drivetrain
Found some good pictures of the angled back 240Z R180 half-shafts, and the perpendicular 280Z R200 shafts. A backward 280Z mustache bar would push the R200 forward. http://www.zhome.com/ZCMnL/tech/R200.htm -
Just check the simple reasons for excess fuel first. Check the vacuum hose to the FPR for raw fuel (blown diaphragm). Excess fuel pressure (the stock FPR is 36.3 psi). Leaking injector. Etc. ECU's tend to short the injector circuit open and flood the engine. Could be the ECU. Is the description below with the ECU unplugged? That would be odd since there should be no injector pulses. Holding the vane closed leans the mixture but also chokes air flow. It should also kill power to the fuel pump since the fuel pump contact will open with the vane closed (as the factory set things up - yours might be modified). You might spend some time in the Engine Fuel chapter looking at how fuel is supplied through the injectors, what the ECU uses to richen the base pulse, what the AFM does, etc. " I had my brother in law hold the wiper on the AFM clockwise, leaning out the mixture, and the car started and stayed running as long as he held it, once he let go, it would immediately run so rich, it floods out. "
19 lb injectors are over-spec. on flow. Mid-40's pressure is over-spec (way) on pressure. You should be running way rich from the beginning. What else did you forget to mention? Are you even using the stock ECU? Has the AFM been "adjusted" to compensate for the extra fuel the out-of-spec. conditions cause? Maybe the cog spring came loose and the vane is free to move.
Motor & Tranny mounts
NewZed replied to 98blackbell's topic in Brakes, Wheels, Suspension and Chassis
Must be this car? http://forums.hybridz.org/topic/112393-datsun-260z-turbo-s15-6-speed-technotoytuning/page-12?do=findComment&comment=1159965 Turbo L6? -
Datsun 260Z Turbo S15 6 Speed TechnoToyTuning
NewZed replied to tooquick260's topic in S30 Series - 240z, 260z, 280z
No torque-HP data plot cross at 5250 RPM? Those curves seem really smooth and oddly shaped also. -
Because turning the AFM vane by hand fixed the problem, whatever it is, doesn't mean that the AFM is the cause of the problem. The old problem may not be related to the new problem. I would troubleshoot more. Could be a simple holed FPR diaphragm.
johnc measured some half-shafts and posted on them a while ago. Here's an excerpt from the Beta Motor Sports article he wrote. I have a free yoke and if I add it's length (1.442" from flange surface to bearing cup hole) to his numbers, I get those shown. He also got a difference of 7/8" side-to-side although his arms were at 7.5 degrees. I think that you got your driver-passenger backward. Driver: 12 .375" + (2*1.442) = 15.259 = 15 1/4" Passenger: 13.25 + (2*1.442) = 16.134 = 16 1/8" "In a R200 installtion, with the lower control arms about 7.5 degrees from parallel to the ground, the driver's side halfshaft's length is 12 3/8" while the passenger side halfshaft's length is 13 1/4". " And, for an R200, the halfshafts should be essentially perpendicular to the hub, or parallel to each other. It's the early 240Z with an R180 that has the diff mounted forward, and the shafts angled back Just reference points. I've wanted to work out the flange-to-flange distance when in the car anyway. More numbers to work with. -
Did you look in the little hole for fuel? http://documents.holley.com/199r8108-2rev4.pdf https://www.holley.com/products/fuel_systems/carburetors/classic_holley/parts/0-8007
- 7 replies
- 4 barrel
- holley 390
(and 3 more)
Tagged with:
BMW's using it in their Safety car. It must be safer. http://m-power.com/_open/s/varlink2.jsp?id=3301&lang=en
So the detail of what you're wondering about is if a 90.5 mm diameter fire ring will seal on an 83 mm bore. I would guess that it would if the sealing surfaces are flat and solid. I don't have the experience to say but I think that's the heart of the question. Kameari only offers 87 and 90.5 options anyway (maybe. Their web site shows 86 in one place and 87 in another) . You're 1.75 mm farther away with the 90.5 than with the 87. The dead space can be a bother but I think it will fill up with carbon quickly. Again, just a guess. http://www.kameariusa.com/l6-metal-headgasket/
Part number? Link?
Fuel pressure drops to zero as soon as motor is shut off.
NewZed replied to Kamaka Z's topic in Fuel Delivery
Never mind, mistake. Erased previous comment. Might just be poor quality on the aftermarket FPR. It might still wear in though, with time. Probably best though, If you confirm that it's the 280ZX FPR, to take it back and exchange it. They're not supposed to leak down. -
You could block the return line and test that way, or block a port on the 76 FPR and put it back on. Or you could just use it for a while and see if the new FPR settles in. Might have some surface rust inside, if "new" means "new old stock". I'd drive it for a while and see what happens. Won't hurt anything. Might be aggravating. If it's leaking at an injector you'll probably notice it's very rich on starting. Might even foul a plug.
