NewZed
72
Everything posted by NewZed
I've read the whole thread and it has drifted some from the original Post #1 (not surprising after 22 pages) but Ricky's post has kind of brought it back on topic, to specific problems at the back cylinders. Ricky stated that they "added the by-pass lines after we had some issues with the engine losing compression on those cylinders which was caused by the exhaust valve seats losing their seal. We used a vacuum gauge to test the valve seat to confirm this." He then reports a stable 190 degrees after ten laps as the result, as opposed to creeping up over ten laps. The question of compression loss and loose valve seals due to localized heating is still unanswered. If this mod has fixed that, then the engine should produce more power over the course of the race (no more compression loss), with no loose valve seats at the end. That would make the result of the modification more clear. I've read the whole thread before and I recall waiting for the definitive results to solving the dropped valve seats, or detonation at 5 and 6 problems, but never really saw it. The closest I recall was a report of producing equal, sharp, "sudden onset" detonation across all cylinders. Anyway, thanks to everyone who does this kind of work and shares it. It's fascinating stuff and I wish I had the resources myself to add more to the discussion.
I thought that the focus of this thread was to find a way to prevent overheating at cylinders 5 and 6, to avoid problems like dropped valves (Post #1) and detonation. Ricky is just reporting a lowering of coolant temperature in general. Which seems a little odd actually, since the same volume of water is flowing past the temperature sensor and the same amount of heat should be produced by the engine. It's interesting work, but I don't see the connection between specific hot spots and overall heat removal.
One possible reason for the engine to idle higher with the flasher fuse out is that the alternator is not working as hard (burning up your wires). Did the ammeter wire smoke before the fuse box upgrade? There's a pretty good wiring diagram at this link, in the FSM - http://www.xenons30.com/reference.html
The descriptions of wire gauge in the FSMs, plus the Courtesy Nissan web page support the premise that Br (Brown) is actually what is now called red and is 0.3 mm^2 in diameter. http://www.courtesyparts.com/kb_search_result.php?chassis_id=59&keywords=fusible+links&Submit_Button=Go&cat=1 I think that Post #12 in your first link is on the mark. The wire gauge is listed in the FSM. The only reference I have seen on the internet to red as 50 amps is the atlanticz site, and on the atlanticz site, they call red out as 0.69 mm^2 not 0.3 as Hyuri says (in your link). It would be great if blue would address that issue someday on the atlanticz site, since tens, hundreds, maybe thousands of people take it as Z gospel. Luckily it only really matters if you have a short. It's interesting that the ZX fusible link cover still shows Br for link color, but the stock link looks red.
Here is a starting point for you - http://www.xenons30.com/reference.html Good luck. You'll probably be in the Tool Shed by end of day. Do you have a 5.0L 240 - 260Z or is that your plan? Edit - I'm a slow writer. At least he finally got a couple of responses.
Your jumper wire just did the same thing the fusible link did. It melted because it had too much amperage through it. The components on that circuit,including your fuel pump, should not be pulling enough amps to melt the link or the jumper. There must be a short somewhere in the circuit. By the way, red may not necessarily be a 50 amp link. There is some confusion about it in the 280Z world. I'm not familiar with ZX's though, but you should probably confirm it or you might melt the next weakest link in the circuit with your 50 amp fuse. The wiring diagrams should tell if one of the components that you upgraded has a direct connection to ground, that you might have reversed.
The fact that "sometimes" you have to push the pedal to the floor suggests that your slave or master cylinder is going bad. Pull the rubber boot off of the slave cylinder and see if it's full of fluid. I had a slave cylinder fail due to bad sealing mid-stroke. It looked like it was moving correctly but it was leaking in the middle of pedal travel. If you're sure the hydraulics are good, then it's possible you have a short collar in place when you need a long one. But if that was the case, I would expect your slave cylinder piston to get pushed out of the cylinder since it is self-adjusting and would just take up the slack (as I understand it). Here's a link to collars either way - http://zparts.com/zptech/articles/trans_swap%20parts/4tobear_specs1.html Edit - these are examples and your situation might not be shown, but it gives you the idea.
280z Fuel Injection System Swap
NewZed replied to mtinney280z's topic in S30 Series - 240z, 260z, 280z
These are popular - http://forums.hybridz.org/index.php/forum/63-ems/ There are threads out there about the Z31 ECU but I'm not sure it's much easier, better or cheaper than the aftermarket options in the sub-forum above. -
Mystery Battery Drain in 1976 280Z
NewZed replied to PhilbertZ's topic in S30 Series - 240z, 260z, 280z
If he still has the external voltage regulator, you might check that out also. One of the wires to the regulator is hot, a direct connection to the battery. Unplug it and see if the light goes out. -
How about a picture of the debris from the header?
Greatings to All!! I'm a Newbie so be gentle.
NewZed replied to teched's topic in Gen I & II Chevy V8 Tech Board
You might have a broken tension rod on the front suspension. They break sometimes if the rubber bushings are replaced with urethane. A broken rod will let your transverse link (aka control arm) and wheel move back and forth. Just a guess, but worth a check. -
WB02 means wide band oxygen sensor. It allows a higher resolution signal to be produced than with the narrow band, and with the right controller gives actual Air Fuel Ratios (AFR) over the useful range that you would expect from a well-tuned engine. Here's a link to one of the most popular units - http://www.innovatemotorsports.com/products/lc1.php Here's one with a gauge - http://www.innovatemotorsports.com/products/MTXL.php One more thing - the graphs in the link below show what you are probably reading, either narrow band or wide. The slope of the curves, negative vs. positive, is even different for narrow vs. wide. You should figure out what you have. http://www.carcraft.com/techarticles/116_0402_innovate_air_fuel_ratio_meter/photo_07.html Just one example. Not an expert, just stuff I've picked up here an there.
This thread should help you - http://forums.hybridz.org/index.php?showtopic=48124 Since I'm here - what do you mean by "2t" in your description of your engine mods?
CSV is Cold Start Valve but maybe the turbo motor doesn't have one. I browsed the supplement and didn't see it. Confirm fuel pressure. Just loosen a hose clamp on the fuel rail and see if gas squirts out. Your FPR and pump should hold pressure for at least a minute or two after trying to start. The dropping resistors save the injector circuit from overheating. I would not run with them bypassed if you have stock injectors. Alright, that really is all I know. Good luck. Confirm fuel pressure.
You're welcome. But. I think that dropping resistors are matched to the injectors (according the FSM the 81 turbo engine uses a dropping resistor, it's described in the 81 Turbo Supplement) to control current flow through them. The ECU or E.C.C.S just supplies the ground. I could be wrong though, I don't have a turbo motor. You could check you CSV connection for 12 volts when the key is at Start, then pop the CSV out, disconnect the small wire to the starter so it won't crank, turn the key to Start and see if the CSV squirts. Or loosen the hose clamp and see if it leaks, or something similar. A lot of different ways to verify some fuel pressure even if you can't measure it. On the 81 doesn't the fuel pump prime for five seconds when you turn the key to On? You should be able to hear it. I would think that if you had some fuel pressure in the lines, that the CSV would supply enough to at least give you a pop or two. Some people have reported running the engine on a stuck open CSV alone. You might supply a direct 12 volts to the CSV, jump in and see if it starts. Just a wild idea. That's all I have. It sounds like you have everything covered except confirmation of fuel pressure in the lines and injectors opening.
This thread has some good stuff in it. Jump to #16 for the apparent answer. You might have enough current for the lights but not enough to open the injectors. http://forums.hybridz.org/index.php/topic/97671-1977-280z-fuel-injection-problem/page__p__917068__fromsearch__1#entry917068 Are you sure that you have good fuel supply and pressure?
Maybe they were monitoring a converted signal from the Megasquirt board, not the actual VR output.
The variable reluctor generates its own voltage. There is no +/- 5 being turned on and off. (Edit - on the oscilloscope) The Megamanual does a pretty good job of explaining it. http://www.megamanual.com/ms2/pickups.htm
It is fairly well described in the Engine Fuel section of the FSM. The ECU grounds the injectors, allowing current to flow and opening the injectors, off of a pulse from the negative post of the coil,when the coil fires. This circuit also runs through the tachometer, so if the tach is disconnected the injectors won't fire. The injector connectors should have 12 volts on both wires, when the key is on. The 1976 280Z FSM chapter files at www.xenons30.com are well-copied and broken up in to individual chapters, so very easy to find what you need.
1977 280z fuel injection problem
NewZed replied to zsteelman's topic in Trouble Shooting / General Engine
The cold start valve only adds gas when the key is turned to Start. Otherwise it just sits there. It is only for Starting. The Air Regulator doesn't add "extra" air. It just bypasses the throttle body to increase the idle speed without having to open the throttle blade. But the air is still passing through the AFM, therefore is metered. Did you block the hoses, or just connect them together? Without the Air Regulator, the engine will not keep running until it's warmed up. That might explain the need for the quarter. If you can't fix the Air Regulator, you're better off to block the hoses, and use the idle screw yo keep it running, at least for tuning purposes. The return spring on the brake pedal will bring the pedal back up. You either have brake lines full of air or a bad master cylinder, or both. If it's air, you should be able to build some pressure by pumping the pedal. Make sure that your water temperature sensor works and is connected to the right plug. It has the same connector as the thermotime switch. If it's not connected properly and working, the ECU will keep adding gas through longer injection times like it's stone cold. The most effective way to check is at the ECU connector. That way you know that the the sensor and all of the wires are working. There's a table of resistance vs. temperature in the FSM Engine Fuel section. Pick your engine temperature and measure at the sensor's ECU connector pins. If one temperature is correct, odds are everything is working. Your problems are very common to all of the old "ran when parked" EFI Z cars out there. I've gone through the same scenario on two so far. -
If your 260 has an ammeter, it will probably be like the 240Z and need the diode. The MSA plug might even work. If it has a voltmeter, then the 75-77 280Z conversion would probably work. I don't know when they switched, but I think the ammeter is what determines the need for the diode. You could compare wiring diagrams to be sure you get the wire colors right, if you don't want to test the individual wires.
Have you tried www.classiczcars.com? Much more likely to get some good help over there.
Where?
I think that Dexron is, in general, associated with ATF and not gear oil. Maybe it's just mass-media marketing. When I see "Dexron", I think ATF. Google "Dexron" and ATF comes up. Maybe there was an 80W-90W Dexron fluid available in 1983. I just put it out there as a possible point of confusion. Maybe there were two manual transmissions for the turbos, one used Dexron, one 80W-90W. I've been in the transmission sections of the FSM and haven't seen anything describing a manual transmission that uses ATF. Dexron is actually a GM trademark for ATF fluids. http://en.wikipedia.org/wiki/DEXRON
