Brad-ManQ45
    9
  1. Tjanks for the update Mike - didn't want to ask.... Hope the recovery goes well. Give my regards to your lovely wife - and tell her I got a new pair of shoes!
  2. At least it's not as butt ugly as the Baja - what was the idea with those big honking lights below the headlights anyway? They should have recessed 'em - probably gone rectangular. Subaru has always been a bit odd...
  3. If you don't need that spacer, I could use it for a T5 to auto conversion I am doing on my '83ZXT.... I've sent a PM... Thanks, Brad
  4. I only run 18-19 " vacuum with a stock good compression ZXT - with a 2mm head gasket, the vac would probably be a bit lower. When does boost start to build when accelerating in 2nd gear?
  5. Don't you mean "BRRR"? How's it goin' up there Garrett?
  6. Since he's using the stock ecu/afm, no adjustment needed - if he were running speed density - definitely! I still think it is the afm to turbo boot - any hybrid I've seen you have to cut the boot back to enlarge the opening, and to do that you have to cut the spring. My car acted EXACTLY like he is saying - after you're off idle and accelerating you didn't know there was a problem....
  7. Christoc: Sorry, just got back into town and my camera is chargine..... The J pipe is attached using the front hole on the bracket itself There are 3 bosses for attaching brackets to the intake on the edge of the intake manifold - these are all in line. The middle boss is where mine is attached. This is actually located just rearward of the bright manifold vacuum tap (which onmy car goes to the fuel pressure regulator) in your picture (but at the edge of the intake). I was out of town on business and had to stay longer than expected. Hope this helps....
  8. Good call Mario - I remember that under boost, the manual says the ECU goes into open loop mode, reading from the tables...
  9. I'm out of town right now - thank GOD for wireless internet.... I wouldn't worry about bolting it to the intake as much as getting a good seal at the turbo and the TB. It looks like the J pip needs to be rotated a bit and moved a bit toward the fender in order to line up properly. I'm heading home this a-noon, so can get a pic posted tomorrow - maybe tonite - depends on if there's enuf light when I get back....
  10. Check to make sure that the boot from your AFM to turbo is not split. (assuming you are using stock ZXT setup) When I had my T3/T4 installed (living in a condo - no place to work), the Z shop that did the work had to trim the boot. When they did it, they cut the spring inside the boot that keeps it from collapsing too far back, and I developed a split in that area - on the underside where it wasn't obvious! A trip to a Z yard got another for $25, and I did it the correct way - no problems now.
  11. I've had 4 of 'em for years and love 'em!
  12. I'll measure my box tomorrow for you - I wouldn't put great speakers behind the seats - you're only using them for "fill" - most of the highs go away because they're mounted so low and aimed at your butt...I used some 6.5" Pioneer co-ax's and have been more than happy. Of course, my system is more for quality than quantity - loud enough is able to hear everything wih the t-tops off at speed!
  13. If you want, I can measure the 1.75 cu ft box I had made for my '83ZXT that holds a single 12" Kicker Competition. I mounted the amp for it, along with a stiffening cap and cd changer to it.
  14. I have a pair of 5.25" Ads mids mounted in custom boxes bolted onto the doors., and tiltable tweeters mounted about 6" from them higher on the door. The boxes basically fit between the seat and the front edge of the door and stick out about 2 1/2"... Very little cutting of metal involved (if any).
  15. jimzdat: Do those EZ Harness's come with the ground wires unlike the Painless kits?
  16. DD = '96 Town Car Weekend car = '94 Q45a
  17. Dude - the Fiero and MR2's came out at the same time - the Fiero may have been first....
  18. Yes, they were available on one or two Chrysler products. Too small for our use though....
  19. But then he won't be distracted - just disgusted....possibly wretching....
  20. I'm glad this subject came up, because I may be looking to get a diesel powered van of some kind. I had stopped by a turbo shop here in Marietta with Warren and heard some stories about some of the diesel engines out there being a real horror story for servicing. Seems one particular motor, no matter what you had to do you had to remove everything and pay out the but for it also - can't remember the particulars, but believe it was one of the Ford (International?) engines.... My dad used to be a purchasing manager for Cummins back in the 50's so I'm kinda partial to 'em to start off with. DR_Hunts' comments were very enlightening....
  21. KnockSense can utilize the stock ZXT knock sensor - which is tuned for the L28 already....
  22. Go to any hydraulics supply shop and they should have the stuff - Royal Brass is where I got mine in Marietta, GA. A LOT cheaper than $7+ bux a 1/2 foot....
  23. HALL... The VR conditioning circuit in MS converts the sine wave output of the VR sensor to a square wave output. The optical sensor already outputs a square wave....same as a Hall sensor.
