HowlerMonkey
So I heard these cars are rated to 27mpg highway?
HowlerMonkey replied to osirus9's topic in S30 Series - 240z, 260z, 280z
Many Nissan ecus whether 280zx turbo, z31, and others will switch to open loop and ignore the 02 sensor usually within 100rpm of 3500rpms. These cars were made when there was a 55mph speed limit and were never expected to cruise at speeds that put the rpms above that point. Two solutions are tuning with nistune if you are using a Nissan ecu or gearing it such that you aren't over the rpm in which your ecu goes into open loop at your desired cruising speeds.- 59 replies
I only use my cell phone for phone calls and tethering since I am mobile much of the time. Not sure how you got that I have fully integrated the cell phone into every facet of my life. Yeah......rode the technology wave writing code in the 1970s and keeping with all new innovation up to now and maintaining a MCSE (no longer called that) since that cert first existed back in DOS and NT 3.51 days. I come from the days of every byte being precious and feel it's a waste for me to pump a couple hundred MB to hybridz just to show a few pics. My vast experience is why I take issue with my experience here...........because I have experienced most all computing has to offer. Searching brings up multiple threads who's suggestions do not help and I've reached the time limit I have set aside for coming up with a solution that works well. If you know a post that shows how to work with this quirky forum software without investing half a day, I would be grateful but have not found it so far.
I am aware of that and wrote that in the post above. I have the images at a new host but it won't let me edit the original post successfully......gives me a database error every time. Tried editing a single word leaving everything else the same........database error. Tried copying the posts with the missing images and editing in the new addresses before posting them at the bottom..........hybridz won't allow linking anymore and you have to create a photo album, upload the pictures, divine the addresses, and then post them to the new thread. I find it stupid that might be forced to make hybridz host my photos......seems like a huge waste of bandwidth since I am on a cell phone connection tethered to my laptop. This means large amounts of uploading takes forever. If anybody wants to see the thread and mods pictures, I am posting a link below to a more reasonable forum who has their shit together. I'm not jumping through hoops because hybridz can't be user friendly. LOL.....won't let me post a link.
Since it seems hybridz forums took a huge step backwards in functionality concerning pictures, you will simply have to use your imagination. Nice work, hybridz
Definitely replace the studs for the manifolds since it is out of the car. If it's got 100k+ miles, and you're itching to do something, throwing in some new standard size rod bearings and replacing the 30 year old rod bolts with either new Nissan ones or arp bolts will probably get you another 100,000 miles out of it and ease your mind when revving it. I would replace the rear main and front crank seals. If you're simply going to put it in and start it, you should have no issues as long as you ensure you can get oil pressure right away. You can look into the spark plug holes with one of those harbor freight skinny lights and look at the cylinder walls a little and taking off the valve cover to look for rust on the lobes is a good idea as is pouring some good oil on the camshaft before you crank it to start it the first time.
Is this the one that used to run NE division races at summit point in the late 1980s?
I'm pretty sure the only difference is PRNDL switch might signal the ecu to idle up when the car is put into any gear other than P or N on an automatic car while the manual ecu might not have that functionality. So you might not get idle up functionality as triggered by the shifter position but it may be possible the ecu will try to maintain target idle speed anyway. It's possible that the pin on the ecu that receives the signal (pin 10) will do nothing but there is always the possibility that the pin has been repurposed for other functionality on a manual transmission car which might conflict with the signals sent by the automatic vehicle.......which is usually a ground sent to that terminal.....but not always. Check pin 10 for continuity to ground with the ecu unplugged and key off to see if you get it when in any gear other than park or neutral. If you can find them, check the 1983 manual transmission electrical diagram and compare it to the 1981 or early 82 diagram which is for automatic cars only.
New Cam and Rockers - odd looking at 500+ miles
HowlerMonkey replied to inline6's topic in Nissan L6 Forum
My thought is that debris went down the oil supply hole when the block surface was cleaned and was pushed back up by oil pressure until it ran into the gasket and got stuck there causing a restriction. -
If you plan to swap crossmembers with a 280zx, remember to consider they type of sump required for each crossmember.
I'm pretty sure it's thinner lash pads that cause problems with retainers because the rocker will contact the the retainers with super thin lash pads.
Turbo seal type? Thrust bearing quesion
HowlerMonkey replied to Spike243's topic in Turbo / Supercharger
And they sometimes don't like to be driven out and replaced so be careful. -
Why not run the infiniti M30 setup. It uses the type II board and will use the same signaling from the distributor as the Z31 and it gives you Nissan consult port.
That steering box puts a hurting on header selection or trying for turbo sweetness. As far as ZX to 810 ecu, years are very important as there were probably 3 or 4 different fuel pump schemes with changes an amount of fuel pump relays and pinout from year to year. What I do know is that a 1982 zx n/a ecu will go into a 1984 maxima as will the air flow meter but that was more lucky coincidence and I doubt it would be as easy on earlier year bodies. If the crossmembers are the same between the later maxima with rack and pinion and the 810, it would greatly simplify things but header or turbo routing is still an issue concerning clearance of the steering shaft as I had to make a custom down pipe for the turbo since neither the z31 elbow nor the 280zx turbo elbow would clear the shaft when I turbo'd a 1984 maxima. Also.....if your 810 has engine mount brackets that sweep backwards to meet the engine mounts on the crossmember, they could also interfere with headers.
........trying to make one plug and play or easily grafted into specific vehicle harnesses. For S130, would there be interest in M30 ecu incorporated into a n/a harness or one that is already turbo or would people prefer it standalone? Is there interest in Z31 with M30 ecu? Would people prefer Z32 style harnessing with the extra effort into getting crank reference without modifying an already expensive 82/83 280zx turbo distributor but rather using a modified cam angle sensor from later cars? Just gathering some ideas
If your L28 has a p79 head, a mechanical fuel pump is out of the equation. Strangely, the P90 turbo heads bring back the mounting boss hole.
I have a L28 in an infiniti M30 and used the 240sx fan clutch and swapped the 280zx fan blade to the opposite side of the clutch which gave me the blade tip clearance I needed as well as being able to add washers to space it further back. Remember also that the transmission mount controls quite a bit of the fore/aft engine locating so a new one might help more than new engine mounts which either harden or simply separate rather than get soft in the case of the 280zx.
Which electramotive engine specs are you interested in? They had at least two and probably more spec. engines. IMSA GTU trim. IMSA GTO turbo trim. A few might have been made to SCCA GT and trans-am rules as well. Probably the most developed would be the last configuration as raced in the mid 80s in GTO by a crewchief of electromotive..........might have been someone else......just a quick mention during a race. The company who did the cylinder head would have the secret recipe and I doubt they are willing to part with it but I'll bet they would build another one for a paying customer if they are still doing that engine family. http://www.sloversportingservice.com/default.html We had a few we picked up when we sourced the basic car to build into Bob Lentz's GT2 car but I'm not sure if Brian from "Datsun dynamics" kept that information or parts. Looking at the SCCA event results and lap times in the link below, I would venture a guess that both Greg Masters and Bob Lentz were running engines of the electromotive recipe but I would venture that Greg took that configuration and developed it further as they were both from "Datsun dynamics" who always had a healthy engine program. http://www.wdcr-scca.org/ClubRacing/ResultsArchiveCR/NEDivSpringNationalSummitPointApril6702/FINALRESULTSFORRace8ASGT1GT2GT3/tabid/652/Default.aspx Bob Lentz ran the inline engine in his first 300zx but went to a newer car with the V6 and now uses rebello V6 that makes around 380hp with a 37mm intake restrictor.
A really tiny hole. If you don't have one, the wastegate could hang open if you have no leaks.
You got too close to the douche index number that determines #1 douche with a few of your posts so he decided to put it out of reach.
Recirculating the blowoff valve from right in front of the throttle plate to the turbo inlet got rid of that "rich dip" in idle speed that happens when I closed the throttle. If you're venting to the atmosphere, your MAF doesn't know that air it just metered didn't go through the engine so you end up with a rich condition at drop throttle that stalls the car.
Some guy named Sanford Silverberg holds the SCCA ITS track record at milwaukee with a 280zx........at least he used to.
Anyone know if there a spec on the limit of how much you can trim off the stock valves?
Take care when "retorquing" old head bolts as you could end up snapping one off since you don't know the condition of them. I would start with a setting on the wrench of a little less than what the factory recommends just to see if you get any movement and carefully feel while you are tightening. If you find one that is starting to turn more than the others or just doesn't feel right, you might want to remove that one and replace it before it snaps off. Overheating an engine can cause the aluminum cylinder head to expand and actually squeeze a gasket thinner........then at normal operating temps. afterward, the head is not fully torqued.
