24
Everything posted by jhm
What year S30? The early-year cars came with open R180s, and some of the last year cars came with R200s. I don't believe any of the standard differentials were LSD from the factory. Most people putting down serious power in straight-line applications use the R200...it's quite a beefy unit. There are quite a few threads here about the different options available, so search and you should find all the info you could possibly want, and make sure you check out the pinned threads too. Hope this helps.
I believe most people have had favorable experience with the Vogtland springs, as well. https://m.ebay.com/itm/VOGTLAND-GERMAN-LOWERING-SPRINGS-fits-NISSAN-DATSUN-240Z-1970-70-71-72-to-73/122344526836?fits=Model%3A240Z&epid=547979549&hash=item1c7c4d53f4:g:O34AAOSw9GhYmPeW
Assuming you're asking the question regarding an S30? If so, what year? IIRC, the early years used left- and right-hand threads; and later switched to right-hand thread on both sides. I've had steering racks with both; and racks can be switched between year vehicles; so make sure you know what you have before ordering replacement parts.
Techno Toy Tuning Tie Rod
jhm replied to Keepn it OG's topic in Brakes, Wheels, Suspension and Chassis
I'm running the T3 tie rod ends and their NCRAs. I like the adjustability of the tie rod ends, the improved geometry as grannyknot pointed out, and the increased clearance between the tie rod and wheels (15x9). Hard to beat the quality and design of T3 stuff. -
Need tires, HELP! 15X9-28 15X10-28
jhm replied to superduner's topic in Brakes, Wheels, Suspension and Chassis
I'm running the 245/40-15 RS4s, and am fairly pleased with them. Can't vouch for their long-term longevity as I've only had them a few months. -
Difficult to say, because every 45 year old car will be slightly different, and you didn't specify what tires you'll be running; but my guess is that you will have some level of interference between the outer wheel/tire and the fenders. If it's not too bad, the fenders can be rolled to reduce interference. With the -15 offset, there probably won't be interference with the spring perch on the strut; but no guarantees. With a few simple tools, you can simulate that size wheel (and tire) and actually take some fairly accurate measurements on your own car, to give you a good idea of what the fitment will be. This is probably one of the most commonly-asked questions; there are a number of threads on this topic. You may have to cull through them to find your exact combination, but chances are it's been already been addressed at least once. Good luck with it.
Actually, Brakekleen is used very commonly to clean bad stains on the interior. I've personally used it on carpets and door panels many times without any problem. For a seat, you obviously wouldn't blast it so much that it soaks through to the foam....you use it on a rag and blot it, like you would with any cleaning product. Good luck with it.
Brakekleen works well for those kinds of spills and stains.
1972 240z Build Thread - Budget Racer
jhm replied to Bruggles's topic in S30 Series - 240z, 260z, 280z
Sounds like a 15" or 16" wheel might be the best all-round solution; in either and 8" or 9" width. There's a decent selection of tires in those sizes (more in 16 than 15) for cheaper prices than you'll find for larger diameter wheels. If you're wanting new wheels at budget prices, check out XXR (or even Rota). Otherwise, keep an eye on the used ads for used wheels. Old Toyotas have the same lug size as S30's, so watch the 4AG forums, as well as Datsun forums.. -
Jon stole the words right out of my mouth....the molded-in headlight covers are really nice. Kudos for bringing an old classic back to life.
- 17 replies
- Cook racing
- Jim cook
(and 1 more)
Tagged with:
Your questions regarding wheel and tire size really need to be prefaced with your intended application. Racing? What style of racing? A setup that works well for auto-x may be terrible on a road course. Off the top of my head, most people will probably steer you to a 16" wheel; but that may or may not be the best setup for your particular needs. And like in all aspects of life, your budget will likely be the biggest constraint, so you'll need to decide how much you plan to spend. Websites like TireRack.com are a good tool for determining what size and quality of tires are available. -
Tachometer illumination issue [Solved]
jhm replied to Oblithian's topic in S30 Series - 240z, 260z, 280z
I guess the obvious question is do you have 12v and good ground at the bulb socket? If yes, the bulb is probably bad. If no, need to troubleshoot that circuit. If you haven't already done so, removing the heater controls center panel makes it easier to work behind the tach. -
See figures AC-61 and AC-64 in the attached. AC.pdf
What wheel specs for S30 wide ZG flares
jhm replied to Clyde's topic in S30 Series - 240z, 260z, 280z
There's actually a wide range of sizes/widths for "ZG wide flares", depending on the specific manufacturer. Which specific flares are you considering? You will also need to specify tire brand and size that you are considering, as well. That makes a huge difference in fitment. Have you had a chance to review this thread yet? -
Yes, it sounds like that one is definitely gone if it compresses and stays compressed. From what I've seen, Tokicos produced in the last couple of years have been hit or miss quality. Bilsteins are a good affordable alternative if you don't feel like springing for Konis.
Wow, great info! Sticky-worthy?
That is correct. Don't know what year your car is, but it can be rewired if you so desire. Do you want the turn signals to operate when the ignition is not on?
Nice price. Didn't know AZC was offering those pieces....may have to look into it. Thx.
Nice parts list! 👍 Dropping some serious change on this build. You may want to consider some adjustable tie rod ends, while you're at it....there's a couple vendors out there; I've got T3's, and am pretty happy with the quality. Apex Engineering just released some, but I don't know anyone that's used them yet.
Couldn't agree more with the advice above. Have seen several members here, and on other forums, recently tackle electrical issues with a random, unsystematic approach....replacing components at random without any deliberate analysis or troubleshooting. Just leads to frustration and lots of time/money spent on needless replacements. BTW, if you determine that your issues are indeed caused by the gauge lamp dimmer rheostat, and if you don't care about the functionality of the rheostat, it can be removed from the system. It's just a variable resistor. I always prefer my gauges on full bright, so I removed the rheostat and jumped the two leads together....giving full current to the gauge lamps whenever switched on. Good luck with it.
1972 240 brake problem Help Needed
jhm replied to Strongback's topic in Brakes, Wheels, Suspension and Chassis
Looks like a really nice old 240. You are already WAY ahead where most of us usually are when starting with a newly-acquired Z. Have fun with it, and welcome to HybridZ. -
Congrats on your find and good luck with the resto-build. Looking forward to seeing the progress!
Current flows to the wiper motor through the wiper relay on the relay panel in the passenger footwell. Relay could be bad, but I would test it before replacing. The wiper motor could also be bad. Try applying 12v directly to the motor to test. The wiper mechanism may also be frozen, which would prevent the wipers from working, but they can be cleaned up and lubed pretty easily. Yes, the switch for the rear defroster is typically located in the center console, under the radio.
Were you able to download all the FSM docs you needed? The wiper wiring runs from the combo switch, through the dash harness, to the wiper relay in the passenger footwell....it should not have any connections in the area of the radio. There is a plug on the firewall inside the engine compartment which can become loose and/or corroded, causing the wipers to fail. Hope this helps.
L.E.D hazard bulb issue...plz help!?
jhm replied to jersey280's topic in S30 Series - 240z, 260z, 280z
SJ, that's a bummer....sorry to hear that it didn't work for you. I went back and checked my flasher unit, and I'm pretty sure it's the same one you bought from Amazon. It's been working fine for almost a year now. Weird. The good news is that these are obviously becoming more popular, cheaper, and more readily available. Maybe check one out like Miles is running. Sorry again the unit from Amazon didn't work for you.
