calZ
    19
Everything posted by calZ
  1. Right to the cage is how I prefer it, as long as the straps end up at horizontal or with the mount points lower than your shoulders. I'm sure both the harness manufacturer and the SCCA have specs for the acceptable range. You'll have to check for rubbing on the seat as well.
  2. This is a lot further forward than the cowl would be, but see my old MR2 racecar as an example.
  3. One thing I see a lot in automotive aerodynamic discussions online is that people tend to group things into "high pressure" and "low pressure" areas, when in reality it's anything but binary. The cowl area is definitely near the upper end of the pressure range, but as long as the engine bay is even higher, air will still flow. There's been plenty of people who run a popped hood and get better cooling, which shows the potential, but the cowl vents are much closer to the windshield in a relative sense. Are you allowed to add metal the outer body of the car? A raised flap/ramp in front of the cowl openings would almost assuredly make the pressure gradient favorable enough to get flow how you want it.
  4. My day job is doing aero analysis and design for a defense company. A big thing when we design planes is that to reduce drag, you want to capture the absolute minumum amount of air possible in the inlet. For the purposes ot a car, the inlet would be the grill opening. It's pretty common knowledge now, but ducting the radiator and blocking everything else off has huge benefits. In my experience, a lot of people who work around certain things think they know a lot about it just because they're near it. Welders thinking they know structural design, contractors thinking they know architecture, and apparently Bob thinking he knows aerodynamics.
  5. Your setup sounds good to me. As Tony mentions in the link I posted, it sets up a siphon with freshly cooled water from the rad once you turn the engine off.
  6. I always thought the "correct" way was feed from the thermostat housing and exit to the water pump inlet. There's some discussion about it here https://forums.hybridz.org/topic/130709-l28et-cooling-system-layout-critique/
  7. For that, there's the self-learning FI systems that just replace the carburetor. If you want anything more complicated than that, there's a large step because you can't use the existing equipment on the engine.
  8. If the pedal travel is too much, just upsize the master cylinder.
  9. You can actually get 275s in the rear without flares as long as you have adjustable suspension
  10. It only happens when the page loads slowly. It starts as the Skillard logo and then swaps over. It seems like either a redirect or the logo updating as more page elements load.
  11. I'm talking about the favicon. The little icon that displays on the tab next to the page name, or is the only indicator of what the tab is if you're on a mobile browser.
  12. I may just be crazy, but I've noticed the last couple days that when a page loads slowly, the Skillard logo is on the tab, and then transitions to the HybridZ logo. Does Skillard own the site now? Just hosts it? Or is my phone having a strange glitch and I'm just dumb?
  13. I'd think 1/2" would be within the realm of just rolling your fenders rather than going through the work of adding in new metal and blending it.
  14. Are you going to be street driving the car? You don't really need a speedometer on the track IMO. If you end up getting a lap timer, many of them can display MPH as well.
  15. I saw the snippet about 3/4 when reading about the head yesterday. Do you know if he did anything specific to alleviate the 5/6 problem? Is his plan for that just the internal changes being enough?
  16. Just for the casting, right? Rockers, valves, etc will add up
  17. Your car still has an ammeter, not a volt meter, correct? Someone might correct me, but I believe all the alternator current flows through the ammeter, so if your gauge is fried it would block the current and prevent any charging at the battery.
  18. Ah, that'll do it. I was going to say it you were not going with a cage, having the rockers off would give you a good opportunity to add some interior tubes for strength. Probably a good idea to have a cage in a 240Z with 600hp anyway.
  19. Yeah, Hoke retired from Datsuns, and I think Godzilla only sells them as part of their kits. You might be able to email them and get one separate. I really just meant that I assume since all 3 people that offer(ed) them did floor mounts, it's likely that there isn't room. It could just be for simplicity though. Are you putting a CD009 behind an L-series, or do you have a different engine?
  20. The CD009 is so wide that you have to remove the stock ears, so it's possible you might not have room for tabs. Hoke and Godzilla both have floor mounts too. That could be so customers don't have to weld, but you might just not have room.
  21. 1. No one is going to see your brake ducts. They're behind the wheels and should 100% be form over function. 2. Half an hour with a hand drill and a tap is all it would take to make the 4 holes usable again. 3. You're just feeding air to the center of the rotor, so the shield/bracket shouldn't need to be very big
  22. Why do you need a re-think? Wouldn't you have noticed if your cardboard mockup hit the tie rod?
