calZ
    18
Everything posted by calZ
  1. It's slowed down a bit, but it's still alive
  2. No flat spot for a wrench at the top of the shaft? An impact will work to tighten/loosen them. We used to do it frequently on the race car. The shaft spins, but there's enough resistance that the impact will tighten it down.
  3. Well, it depends on a lot of things. An LS is going to be the cheapest and easiest to get that kind of power. Th RB keeps it Nissan, but they're expensive. A JZ will get you all kinds of street cred at import meets, but they're also expensive. What's your budget? Do you care about lineage? Manual or auto trans? There are so many more factors than just the power level
  4. The oil still gets run through the filter eventually, since not all the oil goes to the same place each time through.
  5. We loved Raybestos ST-43 pads in our racecar. A lot of the endurance racing guys swear by them. Their bite is pretty consistent from cold to hot, and they wear like iron.
  6. I'd say follow the manufacturer recommendations. I know Koni says no boots, but others suggest them.
  7. Got it. I thought it was probably something like that.
  8. What exactly is a zero hole?
  9. I've ordered from them a few times. The only issue I've had is they didn't send a part, I asked for an update, and they replied "Oh its back-ordered for 12-16 weeks. We'll let you know when we get them in." They were prompt about issuing a refund when I asked for one, though.
  10. What's the name of the shop? It would be interesting to look at the pictures on IG.
  11. I suppose an alternative would be to just have the ECU(will be a Haltech in my case) output the wheel speed data to the MK60. I believe I could setup an output that scales one set of the VSS pulses to match the number of teeth on the other set. The MK60 wouldn't know the difference.
  12. Big Sur is a great choice for a stop. I haven't been there in a few years, but Julia Pfeiffer State Park is right on PCH and has some nice little hikes if you're into that. You might also be able to catch some elephant seal stragglers on the beaches near Hearst Castle.
  13. I've long been planning on and working towards having traction control in my car. I've been doing some reading about the MK60 units. It's handy that it outputs the wheel speed and yaw data as raw values that ECUs can read as regular inputs. It avoids having to make the can systems communicate. The only downside is that the ABS unit requires the sensor ring on each wheel to have the same number of teeth. I haven't pulled my R200SN off the shelf to count, but I'm guessing it doesn't have the same number of teeth as the Subaru tone rings I have for the front.
  14. What are you using to control it?
  15. What brand is the ABS unit? Aftermarket or pulled out of another car?
  16. It doesn't affect the actual spring rate, but it changes the wheel rate. The further you space out the wheel, the longer the moment arm pressing up on the spring, reducing how stiff the suspension is.
  17. https://forums.hybridz.org/topic/128708-wide-body-build-thread-fiberglass-mafia-kit-molded/
  18. I would guess the fact that it was displayed at SEMA gave it a good price bump, and yes, it having an RB26 definitely upped the price compared to a big block Chevy.
  19. https://www.speedhut.com/ecommerce/product/2585/SpeedBox™-GPS-VSS-to-Mechanical-Drive-Speed-Converter You may have to do some work to adapt the threads.
  20. Got it, thanks. The Interior Innovations door cards have extra seams that I'm not a big fan of, so I was hoping they matched well. JF Customs(the eBay seller) also sells a leather console and dash that I was thinking about buying, which would presumably be the same color as the door cards. In your opinion, are the shades of black different enough that it would look funny if one is on the tunnel and one is on the console? I guess the original vinyl and plastic weren't the exact same color either, but they were at least different materials.
  21. I was looking at some interior stuff today and ended up coming to this thread. How well would you say the ebay door panels match the Interior Innovations leather? I like the look of both of them, but it's hard to tell from the pictures if one is a lot smoother than the other.
  22. OBD-II wasn't standard until 1996, so no, you won't be able to plug an OBD reader in and get full diagnostic data. Hell, OBD-I wasn't even a standard until 1988.
  23. Ironhead, were you pressing out the races or the bearings? All the S30 front hubs I know of, including my T3 hubs, use tapered bearings that don't press in.
  24. Oh, I hadn't even noticed the passenger seat was different. The passenger seat looks like it is actually an LXB, so you might be able to get something out of it, even though a pair would be better.
