NewZed
71
Everything posted by NewZed
	http://www.nicoclub.com/archives/use-nicoclub-coms-factory-service-manual-database.html
	Considering the MS document, doesn't that just mean you were looking at the plug upside down. Or something like that. The order is the same for each. The line drawn on the LS2 picture implies that it also grounds the A pin through the coil body. Maybe a resistance check of the four pins to the coil body (mounting points) would be the easy way to find the A pin, as a reference point. For future wirers.
will the factory 73 temperature gauge work with a ka?
NewZed replied to sid240z's topic in Nissan 4 Cyl Forum
Teach a man to fish or hand him a fish, plus several more. Are you sure that the curves are the same? I can't find the full curve for 1976 (or 1973) but the FSM says that 116 ohms = 50 C (BE-46, testing the gauge with a resistor). Plotting 1995 Pathfinder data, (EL-41) gives ~96 ohms at 50 C. It's on the low temperature end so less relevant, but still not the same. -
So I heard these cars are rated to 27mpg highway?
NewZed replied to osirus9's topic in S30 Series - 240z, 260z, 280z
The 3.7 is going to make your odometer readings high unless you changed the speedo gear in the transmission. Same with low profile tires, it's diameter that matters, not width. so your calculations may be off a little bit. My 76 essentially stock 280Z gets about 20 mpg, mostly city with some highway and it runs great, with plenty of power,and very little gassy smell. I've seen a variety of "surveys" on forums and it seems like most people are around 20 to low 20's on mileage, on the pre-O2 sensor cars. I also have a potentiometer on my cooling temperature circuit and can "trim" the circuit while driving, from lean to rich (I have an adjustable FPR so start a little bit lean). The engine is much more responsive on the rich side. Probably because there is no acceleration enrichment until WOT on the early EFI system. So I run on the rich side, for fun. The higher gas mileage people may be leaving some engine response on the table to get their high numbers. It's not obvious either, unless you can play with enrichment while driving. Mileage is also worse in the winter than in the summer, possibly because the air temperature compensation is not quite right in the stock Nissan ECU algorithm. Just a guess on why, but I get 1-2 mpg higher every summer when it's nice and hot out. The 20 is a summertime number. The starting then dying with the angry noises isn't normal. You haven't mentioned your timing specs. either. "Fine" at idle may not be fine while driving. Ignition timing can have a big impact on gas mileage, and performance. The distributor advance mechanisms have to work properly, they're often corroded on the old distributors and don't.do what they're supposed to do. Have you given the engine a good tune-up, including valve lash adjustment? It sounds a little noisy in the video and your vacuum readings are on the low side. By the way, those $15 JEGS gauges aren't very good, I had one that hid a fuel pressure problem from me for quite a while, a few years ago.- 59 replies
Compare resistance values between the two sensors. Use a meter or check the FSM's. My 95 Pathfinder FSM has resistance values listed, just like my 76 280Z FSM. They call it the "thermal transmitter" in 1995. -
	Get a voltmeter and start probing. Eventually you'll find a spot that has no voltage when it should. Once you try it you'll never go back.
	A lot of the P79/F54 ZX engines have the K cam. It seems to have been neglected when someone put the specs. out on the internet (specs. which may or may not be totally correct anyway). It's the standard NA cam for the ZX engines. The specs. in the FSM are probably as close to right as you'll get.
	Total rookie on head work, but would new valves be an option? If you can't find pads, or they're very expensive. Maybe the valve tips were dressed to equalize lash and it was overdone. New valves might get you back to where you need to be. Page 80 of the Honsowetz Modify book says that Nissan Motorpsorts has up to .330" stock lash pads. Of course, that was in the year 2000. They might be out there somewhere. Feel free to ignore...
	Save the thing you want to paste as an image (.jpg or whatever), click More Reply Options on the Hybridz page, and attach the image. A great tool for saving images is the Snipping Tool in Windows 7 and beyond. It's in the Accessories folder. It saves files with a .png extension.
AZC vs Datsun parts LLC big brake kit
NewZed replied to ECUAdam's topic in Brakes, Wheels, Suspension and Chassis
Don't overlook reputation, competence, and trustworthiness. DatsunParts LLC is relatively new and has made some mistakes in the past, for unknown reasons. AZC has a real person with what seem to be real skills, and a good reputation behind him. DatsunParts has a mystery person, of unknown skills, with a sketchy business reputation. It actually looks like he's selling other people's products under the DatsunParts name. And the fine print won't make you feel comfortable. We have included NEW Wilwood Calipers, Pads, Hoses, Brackets all for a direct bolt on! However some minor drilling and adaptation may needed to be made to make this kit fit properly as not all Z cars we made 100% the same as modern cars. We recommend professional installation by a fabrication shop with experience and comfort with these type of conversions. **Note, you will NOT have an ebrake funtion with this kit** Why buy from Datsun Parts LLC? We are a professional licensed Datsun Restoration Business. Our parts are backed with a 100% money back satisfaction guarantee. All we sell are quality new and restored parts that are sure to fit your special application. Our goal is customer loyalty and we want your return business. Our feedback rating is one of the best and our website is listed with several customer reviews. Trust in a ebay pro seller! -
	A torch on that fitting would probably get the male portion out. The brake fluid will boil and smoke and might catch on fire but it's not a big deal. Expansion from applied heat has amazing effects. And a wrench on the block itself will take the bending bracket out of the picture. OReilly Auto and other parts stores have a selection of pre-flared and fitted brake lines of different lengths, with the proper metric fittings. It's the quickest easiest way to get back in action if you don't want to make your own. Many have pre-fitted fuel lines also, usually called fuel line repair kits. I've done all of these on my car.
Just got it to run right. Now it doesn't start, help?
NewZed replied to Thebadinvestment's topic in Z31 Series - 300ZX
The cooling system is always pressurized, so the thermostat opening is not what caused the cap leak. It could just be a bad cap or it could be signs of a head gasket leak. Pull all of the spark plugs and look for signs of coolant. When the engine runs combustion gases get pushed in to the cooling system. Then, sometimes, when the engine stops running the coolant pressure pushes the coolant in to the leaking cylinders. That's just one possibility. There could be other things going on. Do you have the FSM? They're free to download at nicoclub.com. http://www.nicoclub.com/archives/nissan-300zx-factory-service-manuals.html -
Alternator upgrade does'nt charge battery
NewZed replied to s30kid's topic in S30 Series - 240z, 260z, 280z
The stock setup does essentially that but there's a fusible link in between. Otherwise you could short your battery through a bad alternator or an accidental ground at the B post. -
	It's not a stock Nissan relay, it's aftermarket. You'll have to see what the wires are connected to. The connector and its wires colors will offer good clues.
	With a bigger, torquier motor, you could just change the rear diff ratio to get the highway RPM down. What ratio does the car have now? The 73 automatics came with 3.54, you could go to 3.36. Seems like you might just be assuming about things you need, and things that are possible. You don't want a 5 speed auto, you want an auto with overdrive. Which doesn't appear to be available for the L engine. Who knows though, maybe you can swap the bellhousing with a more modern transmission.
	You might consider cooling (and heating) the transmission oil from the outside. Use the case, it's aluminum and will transfer heat well. The same concept as the cooling fins on a differential. But you could add another interface or two to get the heat transferred to the coolant that passes through the engine's radiator. A heat transfer block with flowing engine coolant would heat the transmission and its fluid faster but maintain temperature at a lower level. Might be as easy and effective as trying to pump high viscosity fluid out and back in.
- 11 replies
- 240SX
 - Mechanical fuel pump
					(and 2 more)
Tagged with:
	You didn't really specify. Never heard of 5 speed Datsun automatics but it looks like other countries might have had them. Good luck. http://en.wikipedia.org/wiki/List_of_Jatco_transmissions
	Pretty sure that the L28 will swap right over on to the current L24 auto trans. Why would you think any differently? They're the same block. Make sure you swap the spacer over also from the L24's crankshaft.
	Best to just get a meter and make sure power is getting where it needs to go. The EFI system has its own fusible link, inline on the supply wire at the positive terminal. It's green.
	He's saying that the starter gear is getting bound on the flex plate? Seems like a stretch. Cheaper to try a new starter first. You could probably examine the flex plate through the starter hole too.
	People sell cars without titles because they were unable to get the title. This has big mistake written all over it. You're wasting your time. I wouldn't take it if it was free.
	So shipping costs or gas for the drive. How is your locale for emissions? 280Z's are usually in the emissions testing range, for idle at least. Clear title? Dealing with title issues from distance can be difficult. Looks like a lot of work for not much.
240Z clutch master cylinder clevis
NewZed replied to Mike Mileski's topic in Brakes, Wheels, Suspension and Chassis
Click on the first link I provided, then click on Clutch Master Cylinder, click the year range, and you'll be able to find a drawing of the piece you're showing. Not sure why that wasn't clear. Click, click, click, drawing. $9.xx at Courtesy Parts, plus shipping. It comes with the rod though. Why would anybody sell just the clevis? I'm surprised that Nissan sells the rod and clevis as a separate item. If you're master cylinder isn't factory stock, then you're just shooting in the dark anyway. Edit - a closer look shows that Nissan does sell just the clevis. Weird. They call it the "Head". $3. Assuming that they actually have it. -
	Interior pieces are hard to find in good shape. A nice interior adds some value. You should break things down based on what you want to do with it. Is it a project to work on, a driver that looks nice inside and out, a performance car, a base for an engine swap, whatever. It's basically a 280Z that's been messed with. The bumpers have been swapped and the EFI has been removed and replaced with carbs. You'll spend a lot of time and some money getting the carbs tuned. they're probably tuned for the 2.4L engine they came from. Pennsylvania uses a lot of salt. There's probably a lot of hidden rust. The 50K miles is probably 150K.
Looks like you can get it with the rod. Maybe, assuming they really have it. Try your local dealer. http://www.carpartsmanual.com/datsuns30/DatsunFairladyZIndex/PowerTrain/TransmissionCase/5Speed/tabid/1702/Default.aspx http://www.courtesyparts.com/
