26
Everything posted by madkaw
Looks pretty ! sounds like a good combo
That AAR switch is looking better all the time . Took another stab at my IAC and learned a little more , but still not getting it. I think we need a session Richard. pretty sure it’s all settings in my firmware , but not getting settings right. Not enough idle at first start - though it does stay running and idle is steady(1100rpm) . Idle will pick up slightly as it warms , but that might be enrichment backing off a tad . Fully warm the IAC doesn’t close all the way so idle stays high(1200-1300). If I go into test mode (while running)and test homing position( set to close) , idle drops to exactly where I want it (850), and where engine normally idles at without IAC connected. So the valve is capable of closing , but doesn’t do that all the way when warm . If I stop test mode the IAC steps up 20 steps and the idle increases . I tried to ‘0’ out last step in warm up , but it didn’t seem to want to take it and always went plugged in 20? So all this babbling is just saying that I cannnoy get my settings right , but the hardware should be getting me there.
My '72 240z project -- Rotisserie Restomod
madkaw replied to jkelly's topic in S30 Series - 240z, 260z, 280z
Nice work- 76 replies
- restoration
- metal fabrication
- (and 19 more)
5 options- rebuild stock damper and use your flywheel to trigger . More labor , less cost . Hall gear tooth sensor -35$ Drill press , welder .
Probably should state stuff like bore size, cam, etc...
I think I have one sitting on a 82 intake behind my GARAGE
yes it is-but I had/have so many other issues I didn't know if switching directions was helping me. I think I have a plan now. Just need to get off the RR and implement ! Wish I was retired like the Chickenman!
Actually- I am still set up closed. From a DIY article https://www.diyautotune.com/support/tech/other/stepper-iac/ First, make sure that the idle control is set to “Stepper Valve”, not PWM or on/off idle control. For initial testing, we recommend using open loop instead of closed loop. Closed loop requires more complicated settings and has more that can potentially go wrong. The time step size is how long the stepper driver will command an individual step. If the valve is perfectly dialed in, this will match the time it takes the coil move the motor through a single step. If this value is too low, the step is not completed, and the valve does not move. If the step is too high, the valve will move more slowly than it can – but otherwise there aren’t any consequences. Your best bet is to set this for 10 ms, then decrease until the valve no longer moves. Then add 0.5 to 1.0 ms. 4 wire valves that turn freely usually need to use “Always On” mode. Valves that are difficult to spin by hand usually need to use “Moving Only” mode; the same goes for all 5 or 6 wire valves. The homing steps (called “start value” in older code versions) needs to be set to a large enough value that the valve retracts fully from any position the valve can reach during operation. The current MS3 and MS2/Extra code allow you to specify if the valve closes or opens on startup. Regardless of which position it is set for, you need to set the number of homing steps high enough that it will move all the way to this position no matter where it starts I guess I need to change this in my tune. I believe 'turn freely' explains or describes my stepper
Thanks Richard for your input as always . MS recommended using open loop so that’s why I chose it -thinking it would be easier . Ill try some of your settings when I get back into town .
Made this video to help explain my dilemma .
You know your going to be told to do some searching . So you want someone to write out a complete recipe for 300 Hp using what engine , head , engine management , induction , ignition?????
AARRRGGHHHHHHHHHH!!!! This IAC is PITA--OMG, ready for the BFH. After getting on the forums at EFI and doing some board changes I got the stepper to operate. Now much of this was my fault because I had a broken pin on my connector and wouldn't you know it was one of the coil sides of this stepper. The guys on the MS forums help me thru that crisis, but still can't get it to operate the way it should. Basically it is working the opposite way I want it too. It idles faster as it gets warmer. Can't tell if it's tuner studio or wiring. I don't think MS does very well explaining things on setting up these IAC's. Jeep IAC madness.msq
I believe 460 lift is max for stock springs
Plug and Play Megasquirt Wiring Harness + sensors etc
madkaw replied to softopz's topic in Group Buys
Not trying to be a moderator here, but can this thread be rewritten in the vendor forum or here so it makes a little easier decifering ? Or if the original post can be edited . I was reading it today for someone who wants to order , and it was kind of hard to follow . Thanks -
Missed that page - thanks . That helps a bunch. Didn’t work with throttle plate closed , so next cold start might get it right
This was the big question . I️ know it was partially open , but wasn’t sure that if that was the way it was designed. I️ could pinch the vacuum side and get the idle to come down .
IAC made it's first test run today. I have no clue what I am doing as far as adjusting this thing -but have found a few write ups searching . Initially the idle slowly increased as the car warmed up, so I figured it was wired up backwards , so I switched the wires. I think I got that figured but the idle is still too high(2000 rpm). In test mode it showed fully closed on the guage-if that means anything. I guess I should establish whether this valve closes completely when it's closed. With my 240sx TB I have the throttle plate adjusted for idle, so if this IAC doesn't close all the way then I guess that's my issue. I guess I don't know if this IAC had complete control of idle on the Jeep TB's. Maybe my settings are just screwy? Can't stop fucking with it.msq
L28 Build Thread 75 280z (N/A to Turbo Conversion)*UPDATED
madkaw replied to RefreshRate's topic in Nissan L6 Forum
I think you can have a fun fast car without doing a compete engine swap. You have a short block that will take 300 on a regular basis from all I’ve read . 300 would be very fast and it sounds like you have a nice set up already. Of course this is Hybridz too:) -
2&4 are your major problems . Test will not be accurate at all with those two oops
- 31 replies
- fml
- more z car torture
(and 1 more)
Tagged with:
I wouldn’t give the bottom end another thought if the oil was changed regular . These motors are as tough as it gets -
Let’s add that someone on this site is selling basically plug and play MEGASQUIRT for these engines and some loaded tunes already ! -
And I’m not pushing Megasquirt because there’s other options out there as far as controllers . I’m not a fan of the 4bbl intake -just on looks alone- and the intake you have should function well. There is good support here for MS and as you can see you can clean up the bay nicely . Cam selection is part of the whole equation , but I’d say go big or go home . These engines like to be cammed. CR will be low with that motor compared to a flat top. You could do every thing in steps. Get programmable EFI in first and then shoot for HP and hotter motor later -
