NewZed
71
Everything posted by NewZed
Check the hoses to the core in the engine bay at the firewall and the return line to the front cover. Also check the back of the head where it meets the block. The HG can leak there.
I don't know why Rockauto even has that AC Delco switch on that page. They are slipping. The description is all wrong for the car, even the brand. The Beck Arnley should work. It's a sensor.
You should put the part numbers or links in to your post. Nobody knows what you actually worked with. The hole is BSPT. After 1977 the sender was combined with a switch. Those parts has two terminals. One terminal is the pressure sender and one is the switch. You can use that on your 76 and just leave the switch terminal unused, if you already have one. Beck Arnley has been supplying Z parts for years. Their sender probably works. If I was starting from zero I'd go with that one. It has the best odds. p.s. make sure that you use a thin wrench on the flats to tighten it. Don't try to turn the body it will break loose, spin, and damage the guts. https://www.rockauto.com/en/catalog/nissan,1976,280z,2.8l+l6,1209226,electrical-switch+&+relay,oil+pressure+sender+/+switch,4588
That "shell7" link I placed above is a page of the JTR web site. https://jagsthatrun.com/collections/datsun-z-parts
- 13 replies
- companion flange
- driveshaft
(and 1 more)
Tagged with:
The R180's have axle holes surrounded by five bolts. The R200's don't. For some reason I can't figure out the side view that you showed, the axles are in shadow. Also the R200's have a rectangular chunk of aluminum on the bottom of the diff cover. Your second picture seems to show it but it would be upside down. Can't see the drain plug to know what's up or down. It looks like an R200 but those are bad pictures.
- 13 replies
- companion flange
- driveshaft
(and 1 more)
Tagged with:
This might help. https://shell7.tdl.com/~jags/Pages/Parts_DAT_driveshaft_flange.html
- 13 replies
- companion flange
- driveshaft
(and 1 more)
Tagged with:
What years 280Z? The 75 280Z's had R200's with the same pattern as the later 300ZX's (I thought..). They were oddballs. Check your driveshaft u-joints to see if they are removable, look for the internal clips. 280Z's had staked u-joints, not replaceable without machining. Here's some part numbers from an old thread, below. I'm not sure what's what in the thread, I thought that the 75 280Z parts would fit the 300ZX diffs. Not sure which if these is which, but it shows where your problem probably started. You'll have to do some more searching and checking of your parts. https://forums.hybridz.org/topic/113866-280z-r200-differential-pinion-flange-wanted/
- 13 replies
- companion flange
- driveshaft
(and 1 more)
Tagged with:
This is reasonable. Worth checking. Don't make decisions based on assumptions. Make the assumption then check to see if it's happening. Is your tachometer needle behaving normally? Does it seem like spark is happening correctly?
I don't think that you can say this with certainty.
Just curious, but many people have mentioned looking at your diagnostic data. Is there some reason that you're not? You're obviously able to change the settings, you changed the injector values. If you look deeper you might find something. So far it's just been guessing about a clicking noise. If the injectors are dumping fuel you'd smell in the exhaust and see it on the plugs. Are you seeing signs of running rich or assuming that it's rich. I remember on my 76 when the idle got too low the fuel pump relay would cut fuel and the engine would stumble until I hit the throttle to raise idle speed. In the cabin you'd hear a bunch of clicking noises. Maybe the clicking noise is a relay or two and not the injectors. Keep looking. Good luck.
How about the pickup tube? Could be clogged or maybe it even fell off? If you took the filter off and nothing came out, you're pretty much at the first place to look after the pump. I don't think that system is complicated. Don't know. Good luck.
You might put a mechanical gauge on the pressure sender port to be sure about what you think is happening. Or just remove the pressure sensor from the block and crank the engine over. If you're right, no oil will come out. If you're wrong, there will be a mess. Just a simple test to be sure you're on the right track. Also, are you sure that your drill motor is turning the correct way? Counterclockwise would be reverse on a drill motor.
There are too many pages and I haven't been following, but does your EFI system have any feedback or measurement tools? A "dashboard"? You might be able to pull up injector open duration and see if it's out of whack. That could be an input signal problem. If you have an oscilloscope you could probably measure actual injector open time and compare with the ECU's programmed duration and look for mismatches. Stuff like that. Just spit balling. I'd check your EFI system capabilities though, some of them are pretty sophisticated.
Good luck. Beware the vague terms like burnt or overpowered. With electricity there are two very basic things - breakdown voltage and over heating. Breakdown voltage is when the electricity just "blows through" the insulation, due to voltage over the limits of the insulation, to short circuit to ground, or to the next wire over in an injector. Overheating is what happens when too much current passes through a conductor and creates more heat than can be dissipated over time, which can also damage insulation. With injectors the insulation between the windings is the same for low or high impedance. They both use 12 volts. Peak and hold "peaks" at 12 volts then drops to a lower voltage to hold at a lower current. It doesn't start at a lower voltage. The biggest beware is to know that many of us are just Googling, or guessing. Injectors are pretty durable devices. The odds are very low that your EFI system damaged them. The injector companies will gladly sell you a new set while you try to figure out the true source of the problem. A meter is your best friend. You don't have to be an expert to measure the basic stuff.
But the system would send less current if you had them set to low ohms. Your high ohm injectors can't be overpowered by any of the injector settings. If you had set low ohm injectors to high ohm, maybe. You could pull the connectors and measure resistance with your meter.
The injectors are cooled by fuel. Seems more likely that the injector control transistors would get damaged. But if they are high ohm injectors then they should be more safe if you set them to low ohm. Besides that the power pulse is very short. I don't really think that you can damage injectors with an incorrect impedance setting. Your transistors are probably fine too, they don't see much current. Your problem is probably something else, I'd guess.
280zx (1983) shocks and springs, anyone?
NewZed replied to supernova_6969's topic in S130 Series - 280ZX
You should always get full weight on the suspension and roll the car back and forth before evaluating changes. Make sure the shocks aren't binding by moving the car up and down. And consider tire size, a smaller tire will lower the car but make the gap bigger in the arch. Best to measure from the rocker panel to the ground if you're talking about lowering. Don't blend lowering with tire gap. And drive over a few speed bumps slowly early on so you'll know what's going to scrape later.- 23 replies
[Help] New to me 240z + L28 won't idle
NewZed replied to awk34's topic in S30 Series - 240z, 260z, 280z
What's going on with your advance mechanisms? Do you have vacuum advance connected? Does the breaker plate move freely, or is it slow and sticky? Seems like it was running well then the timing changed and it died and kicked back. If vac advance is connected you might disconnect it and try again. Turn the distributor a bit one way, then a bit the other way if you don't have a light. You're pretty close. I wouldn't worry about the tach right now, the way it ran at the end seems like it has good spark. -
I'm about push this in a lake..Plz help!?
NewZed replied to jersey280's topic in S30 Series - 240z, 260z, 280z
The low RPM driveability problem is super common. Might be that /Nissan tuned the system to the edge for emissions on 1970's gas and it's too lean on today's gas. This fuel tweak really works.- 13 replies
- backfiring
- high idle
(and 1 more)
Tagged with:
Use more words! "Off" which way, loose or tight? "Rough" how? I mentioned the stumbling and bucking. Pretty typical to work your way up to good-running, through many small improvements. They're easy to get running but take some work to get to perfect.- 13 replies
- backfiring
- high idle
(and 1 more)
Tagged with:
They all go at the same time. Another thing to watch is the tachometer needle. If it moves smoothly with RPM that's good. If it jumps around for no reason or reads the wrong RPM, that's a sign of ignition module failure. The ECU's also go bad, usually running rich and rough, until they just die sompletely. Have you tried to drive it yet? These old AFM's are also known for running lean. If that's the issue the engine will pop back through the intake and buck and jerk when you give it light throttle, under load. http://www.atlanticz.ca/zclub/techtips/tempsensorpot/index.html- 13 replies
- backfiring
- high idle
(and 1 more)
Tagged with:
Burnt/bent/sticky valve maybe. Have you done cylinder pressure measurements? Should be at most 185 psi, depending on the gauge used. Maybe the PO shaved the head. Looks like you're doing everything right, for an engine with good working parts. There a couple of odd things though, I quoted above. 1978 used the N47 head. Why does yours have an N42 head? And what type of coil are you using, in detail. The ballast resistor is actually a device that changes resistance as ignition dwell changes. It's not just a resistor. It's not a well-understood device, but pretty ingenious. You might be overpowering the old 1976 ignition module. Zhoob's thought that you might just have spark crossfire seems to fit. Maybe you just have bad plug wires. Move them around while the engine is running and see if things change. Use an insulated screwdriver or wooden stick., or make sure your hands are dry. But here's some more possibilities. - The PO left the PCV port under the intake manifold open, either at the manifold, or at the side of the block. You missed a vacuum leak with your testing. - The PO connected your vacuum advance to "always on'; vacuum instead of ported vacuum. Check your timing at idle and disconnect the vacuum advance hose to see if it stays the same, It should. - The weights on your distributor mechanical advance have lost their springs and your timing is jumping around. Again, check your timing and see if it advances with RPM like it should. - the breaker plate in your distributor is gummed up and getting stuck at high advance. Timing light should tell you what's going on in there.- 13 replies
- backfiring
- high idle
(and 1 more)
Tagged with:
Sometimes that is caused by a flattened cam lobe. The exhaust valve doesn't open all the way. You might recheck your valve lash, examine the cam lobe quality, and also check your camshaft timing using the notch and groove. Cam lobes have been known to go flat very quickly. "After adjustment" is good. Make sure the drivers side of the chain is tight and the timing mark is on zero. Use the cam shaft bolt to turn the engine.- 13 replies
- backfiring
- high idle
(and 1 more)
Tagged with:
Wouldn't the ECU need a MAP sensor for vacuum advance of timing? Also, an RPM signal for centripetal advance. Does the 2J use a crank mounted sensor or does it use the distributor type CAS? Interesting idea. Might be easier to just modify a distributor that has vacuum and mechanical advance to work in the engine, to trigger an electronic ignition. Timing control is the hard part.
Your best option is to study the wiring diagram. That's why they were created. Read the FSM Engine Fuel chapter also, it explains the fundamentals of how an EFI system works. That will help you. The EFI harness is separate from the main harness for the most part. The gauges might take some work if the sensors are different between Nissan and Toyota. Getting the fuel pump control system to work will be difficult, probably. It's described in the FSM also. Using the Cressida EFI system in a Z or ZX is not common. You're kind of on your own.
