NewZed
72
Everything posted by NewZed
You might measure the head height just to know more about what you have. Seems odd that a well-known engine builder would build an odd engine like what you describe. Could be that the heads been milled and everything is actually as it should be. And, as Tony D says, even if it is the low CR blend, it will run. Someone did that on another forum just to get a usable engine so that they could sell a car. Same combination, except it was the stock N42 block and dished pistons. Said it ran great, although they'd never had a good-running engine before so may not know "great", using the stock 280Z EFI system. You can always swap it later if it's a dog. Your real decision looks to be between money spent on pistons and rings, or milling the P79 and replacing valves, or buying another head.
Stock engine rebuild advice - what to ask machine shop, etc.
NewZed replied to 1 tuff z's topic in Nissan L6 Forum
Is the E31 head modified with bigger valves? Seems like the stock N47 head would be the way to go. 100,000 on an L28 doesn't seem like a lot. Is there even a reason to take it apart? Not an expert, just asking. -
Msd to 83 dist w/ 75 wiring. Please double check my wiring :-)j
NewZed replied to Project1's topic in Ignition and Electrical
The first picture looks technically right. It doesn't show that there are two wires to connect for power at Start and On, but that should be figurable. Also, if you leave the ballast resistor in place, it might be useful as a terminal block, instead of trying to attach a bunch of wires to the coil terminals. Move the wire that passes through the resistor over to the terminal connected to the coil. Just leave the condenser if it's still good, it won't hurt and it might help. Make sure the distributor body is well-grounded, that's where the E12-80 grounds. Don't forget to disconnect the stock ignition module, and insulate the wire ends so that they don't short. There seem to be several solutions to the MSD and tach problem. Hard to tell which is best. Check for power to the proper places, and grounds,with the key On, before you start the engine. If you're worried about shorting a wire, just check it for power before connecting to anything, and check that where you're attaching it isn't grounded. There really shouldn't be any surprises unless you like gambling. -
The whirring noise that goes away when you press the clutch is normal. But the metal fragments are not. Those pieces look like bearing retainer, not race, so the balls may still be wear they're supposed to be. I've only seen one failed bearing and it was in the adapter plate. Regardless, you might be able to save the transmission by replacing the bearing before it fails completely. It may not grenade but the misalignment will cause damage.
240z Coolant bypass mod (contains pics and part numbers)
NewZed replied to big2003viper's topic in Cooling Systems
You might be able to thread a 1/2" NPT fitting in there, but that's not the design spec. FYI. -
I don't think that Nissan ever used SAE threads. Metric or BSPT all the way from what I understand. The dripping JB weld makes one think that you may have realized something was off. -
What is "fire depth"? There's already a ton out there on the ZX distributor swap. Here's one - http://atlanticz.ca/zclub/techtips/distributor/index.html There's also a ton on the MSD ignition, how to connect it, and problems with the tachometer. Your posts are full of weird phrases like "stock blaster resistor". Which means you're probably on a phone, using auto-correct spelling. Which means you're not using the full capabilities of the internet, because your phone screen is too tiny. Best to find a computer with a big screen and do some study. Nobody really wants to be your portal to the full-size web. -
Weird. I said the same thing, with an easier path to the information. Too many words in my posts, I guess. We're both repeating things that have been said 100's of time though. The internet's a strange pace.
You have an interesting problem, from a couple of views. One is that the regulator is not Nissan, therefore wire colors are probably irrelevant. I would use wire position in the plug. Another is that the form of the regulator indicates that it's probably one of the solid sate, or electronic, replacement parts. From what I've read, they're fragile and fail often. If i was looking at those parts, trying to decide if I should put the time in to making them work, I'd probably decide to just wire up an internally regulated alternator. You said it's bare-bones, so all you need is S, L, charge, and ground for an internal alternator. Or I'd figure out how to make the parts work, but not put the time in to actually doing it. But if you do decide to hook it up, and it's the right replacement part for your year and model of car (Google the number), wire position in the plug is the way to go.
Probably here somewhere. I'd try a file with the word Electrical in the name. http://www.nicoclub.com/datsun-service-manuals
How much thread sticks through? You could put the nut on, then put two thin jam nuts on top. Jam them to hold the shaft while you torque the lower nut. You'll have to torque by feel though. You could also grind two flats on the top of the shaft and use a thin open end to hold the shaft while you tighten the nut.
Interesting. I would think that the 80's Maxima would use something like the 80's ZX's. I thought that it would look like this F54 manifold (right), compared to a 280Z N42 manifold. Good to know.
If you're new to the old Z EFI system, the fastest way to get them running well, ironically, is to spend the time to go through all of the tests in the Engine Fuel chapter, or the Fuel Injection Guidebook, and give it a Tuneup to spec., before playing with anything. The playing usually just screws things up. The hunt and peck method never works. All of the components and their connections need to be in proper working order. Once you have fixed them all and know they're right, then you can make the minor tweaks to compensate for old parts, or modern fuel.
Read it through twice and it looks like you missed the opportunity to correct the initial simple communication error, and confirmed that you wanted a barbed rail.. Then Pallnet bent over backwards to be a nice guy, paid for your communication mistake (which is clear in the Feb. 5 & 6 e-mails), and gave you the money to start over. You have to pay the time for your error. It says "barb" three times in the list of options that you confirmed, and in your Paypal message. You should have corrected the mistake before you sent the Paypal money.
So you're really asking how much advance the ECCS adds, for 82 vs. 83. I've wondered myself about the timing curves with the computer controlled cars. The descriptions in the FSM are vague, even for later model Nissans. No numbers provided.
Implies that there are short struts with 280Z bearings and axles. Interesting. Found a reference - http://forums.hybridz.org/topic/49194-differential-cv-lsd-hp-torque-r160-r180-r200-r230-diff-mount/ "240s have the weakest stub axles with a smaller diameter 25 spline shaft. 260s got the 240 stubs for the first part of production, then later got the 280s 27 spline shafts. T" Also found this - "280 stub axles can be installed in 240 struts with no modifications and the wheel bearings and seals are the same in both cases. This upgrades the inner part of the shaft from 25 to 27 spline." but I thought that the outer race dimension was different. Now I'm confused. Must be the inner flange that's different and not interchangeable. Looks like you're covered, good luck.
Isn't early 260Z like 240Z? 25 spline? I assume that the hub changed with the strut assembly, which was the short style in the early model S30's. The bearings used are different size, from early to late. Don't know, just asking... The ZX axle will work in the early hubs if the dust shield is modified. It's a way to use CV axles on 240Z's. It's documented out there somewhere. Not a straight bolt-in though.
Ignition switch not working 77 280z
NewZed replied to scruz32's topic in S30 Series - 240z, 260z, 280z
Forget about the locksmith then. You're still not being very descriptive, you didn't answer the important questions. So I'll just give a suggestion - it's not uncommon for dirty battery terminal connections to allow the lights and everything else to work but not the starter. The starter draws a lot of current and the heat will open a dirty connection. -
Are you changing anything else, or did you toast the R180? Not much benefit to the R200. That's why they put the R180 in there instead.
When you turn the key to what position? The beep is Run or On, right? And when you say "nothing" do you mean stuff that was there, lights, disappear? Or they stay on but nothing happens? Big difference and it matters. Are you saying that you don't even get the beep now? The locksmith won't help the electrical switch. You can connect that up and turn it with a screwdriver. That's all the key part does. Turn the electrical switch (the back part) with a screwdriver and describe what happens. -
Nearing the end of the rope on my 280z (text heavy)
NewZed replied to SoCal'77's topic in Trouble Shooting / General Engine
It's a flyer, but that is somewhat symptomatic of a bad ECU or bad ECU connector. The door slam = die also fits. People have had the "blue smoke" problem while the engine is running and fixed it by pounding on the side of the ECU, or wiggling the cable. Not kidding. Others have found that the solder joints at the ECU cable connection are cracked, causing the blue smoke problem. They reflowed the solder joints. I had an ECU that would just die out of nowhere, then restart a minute later. I knew my problem was the ECU because I had just installed it to make sure it was good. Unfortunately, the tests won't pick up a bad ECU. Mine was a bad transistor, the others were bad solder joints. So you can either beat on the side of the ECU, or wiggle the cable or borrow an ECU and try it. One case where swapping parts makes sense. Even at the end of all of the FSM testing, if you don't find the problem it usually says "replace ECU". -
Looks like a part added to improve durability. Thrust block. http://xenonzcar.com/z31/differentialinfo.html
Difference Between L28E Auto and manual Crankshafts??
NewZed replied to KidandhisCar's topic in Nissan L6 Forum
You need to lurk harder. I've never had one but have read often about the spacer on the end of the crankshaft used for the automatic transmission flex plate. Pretty sure I can see the separation line in your pictures. Pry or pull it off and you should be where you need to be. -
List the numbers that you got from the "bible" tests. Coolant temperature resistance versus temperature (measured at the ECU), fuel pressure with and without the vacuum hose connected, ignition timing, etc. Describe what parts are on the engine now, AFM (is it the right part number), distributor, ignition module (is it the stock 1977 unit?), PCV system (all of those hoses on top and under the intake manifold) complete and properly connected, etc. Then describe n detail, with numbers like seconds or minutes, what the problem is. "It dies then takes 30 seconds of cranking with the fuel pump off to start" or similar, whatever describes the situation. Engine dies, won't start is too vague. The EFI system has a lot of parts and they are all connected, and need to be working right. Any one of the things I mentioned above could screw up the way your engine runs.
