Neverdone
    24
Everything posted by Neverdone
  1. If he doesn't get back to you, you may want to look into this https://hokeperformance.squarespace.com/store/l-series-6spd-transmission-adapter-03-06-vq35de
  2. You think about running a triangular gusset onto from the box portion of your mount to the flat portion of your mount? Right now you can get a decent amount of flex laterally on that bend of the angle iron you used. Boxing that in would prevent a possibly very catastrophic failure. Maybe you're ok, but I'm always more of the mindset of, the only way to do it is to overdo it.
  3. God damn Tim...your necromancy skills are on point because that Z was well beyond "not worth saving". Next time you want to restore a car, let me know and I'll trailer you one down from the west coast.
  4. https://zcardepot.com/all-products/exterior/sheet-metal?car_model=974 Just add angle grinder and welder and you're good as new!
  5. Does it run? If it doesn't run, I would assume almost everything else doesn't work on it either. Would this be cheaper than just fixing the sheet metal on your current car?
  6. Anything is possible with a drill, angle grinder, and a welder.
  7. Go get checked out for injuries. You may feel fine now, but until you really get it checked out, it may turn into something more serious later down the line. That REALLY sucks about your car man, but it could have been way worse, and that's a good thing that it wasn't.
  8. If you've got a TIG, why not just make the removable car out of a steel bar instead of paying Cusco a bunch of money to use their bar for something it's not meant to be used as? You can get a steel tube and weld some bar ends onto it for pretty cheap. I go to Clackamas Steel for sheet metal, tubing, steel stock. I'm pretty sure they carry aluminum as well. It would be worth a call.
  9. https://www.amazon.com/Bilstein-34-184530-Suspension-Cartridge-Lowering/dp/B009FU7QVW
  10. Combining aluminum and steel also leads to galvanic corrosion. This will treat the aluminum as an anode and start corroding. If you ever have to run a steel bolt through an aluminum piece, make sure there is some sort of coating around the aluminum so that the two metals aren't actually in contact. For further reading: https://www.galvanizeit.org/design-and-fabrication/design-considerations/dissimilar-metals-in-contact
  11. Are you asking how long the CD009 transmission is? If not, maybe draw a picture of what dimension you're wanting to get. Or maybe just get some of these parts... https://www.mckinneymotorsports.com/prod_VQ-Zcar+parts
  12. To answer your question, No. You can use Z31 5 lug front hubs though. You can then get a custom bracket to attach Z32 calipers to Honda Oddessey Rotors. That's here :
  13. Oh that is lovely. I probably would be a couple thousand ahead had I just bought this... Interested....
  14. Usually people use that engine because their car can only fit a 4 cylinder, and they want to keep it all Toyota. However, it's your car. Bringing up how good an L-series is doesn't make much sense because your car doesn't have one. If you don't like the 302, then other V8's probably won't make you happy either. For the price point you're talking about you could get a 2jz-ge, or an SR20, or if you wanted to spend a bit more, you could yank the engine and trans out of a 350z. (according to car-part.com you're looking at about 1300 for the engine and 600-700 for the trans). Those engines all allow you to have pre-made engine and transmission mounts and pretty well documented swap process. Personally I think the Beams engine makes way more sense in a first generation Celica, but it's a lightweight, powerful engine that has a 6 speed already attached to it at the end of the day. That would be a cool swap in an S30 for sure. Do what makes you happy.
  15. You sure you don't have air in the system somewhere? If everything is working correctly, it shouldn't be doing that.
  16. Nice! Now bore and stroke it, and attach some monstrous turbo to it that will ultimately break everything else in your car!
  17. for a quality part that's well made and comes from a reputable manufacturer and actually works, I'd call it pretty cheap.
  18. https://skillard.com/products/240z-turn-signal-plates These?
  19. Anyone have any experience personally owning this one? https://www.amazon.com/Xenon-3124-Brake-Ducts-Urethane/dp/B0007Z6LXI
  20. It was posted before But I don't remember seeing this video.
  21. I'm no engine expert, but I think something might be wrong with your piston.
  22. Is this a 2jz-ge, -gte? How expensive would it be to hone and get bigger piston rings?
  23. I didn't know the R180 out of the STI could handle that kinda power... Can it? Or Can it because it's so much lighter? Also, don't be like Jay. Always wear your seatbelt.
  24. How much for a 432 Spoiler, ZG Flares, and the Air dam as a kit?
