8
Everything posted by cgsheen
It's finally starting to cool off a bit here in Arizona. It won't be long until we can start working on our cars again. And, for the rest of the country, some nice Stance-USA Super Sport coilovers with four pretty Sakura Garage Camber Plates might make a nice Fall project! I know your Z Car will appreciate it... Order some up on our website: http://sakuragarage.com/products/datsun-suspension/
- 51 replies
A 240z and the trials of trying to reconnect the wiring harness
cgsheen replied to Duff's topic in Ignition and Electrical
The path goes like this: Ignition switch -> ballast resistor -> Tach -> coil (+). With a "jumper" to bypass the ballast when the ignition is in the start position (coil gets full battery voltage in start position). SO... There's a B/W that originates at the ignition switch - with the switch ON it'll have battery voltage (if the other B/W and G/W are disconnected - they will have 0V...) That B/W connects to the ballast. The G/W connects to the other side of the ballast and feeds the Tach. The remaining B/W comes from the Tach and connects to the coil (+). In the harness, there's a G/W that "tees" into the G/W that goes to the ballast. It's connected to the "start" signal. So in the start position full battery voltage goes through the Tach and to the coil. It's not a concern at the coil area. It's a current sensing Tach, so I believe it needs to run through the ballast resistor to be accurate (If it didn't matter, I don't know why Nissan would run wire all the way from the ignition up to the coil area (ballast), then ALL the way back to the Tach, and then ALL the way back to the coil...) But, the earlies aren't my strong point. IDK if the ballast can be bypassed (eliminated) and have the Tach operate correctly. -
Thank Goodness Summer is almost over!!!
Max wattage headlight bulbs with stock wiring?
cgsheen replied to Midri's topic in S30 Series - 240z, 260z, 280z
Ya, headlight relay kit... -
BEST MODEL TO INVEST IN? 240, 260, 280
cgsheen replied to CHATZ's topic in S30 Series - 240z, 260z, 280z
Exarctly... -
Same trigger wheel (optical disc) is in the early 90's Infiniti M30 and the Nissan Maxima of the same era. Any VG30E (distributor type V6) will have that disc... Here in Phoenix, the early "4-door sports car" Maxima's are all over the parts yards.
I suppose you've already checked the fuel return line all the way back to the tank. Just go back over your fuel connections and tubing. Verify that you have the supply and return lines are connected correctly to the fuel rail. Make sure the fuel rail doesn't have a blockage. I always find it easiest to start at the source and follow the path it takes back to the tank... ( you can disconnect the return tubing at the frame rail and run it into a container. You should have very good fuel flow - the FPR will "back up" the fuel to maintain a certain pressure, but then the entire output of the fuel pump will flow out the return line to be returned to the tank. ) You know how much fuel pressure you should have - ~36.3 PSI with the engine not running - ~36.3 PSI MINUS your manifold vacuum when it is running (unless you're in boost ). That's what the stock ECCS is expecting. My manifold vacuum is usually 10-11 PSI (maybe 11-12) at idle. And... you can always run an aftermarket FPR...
Of the 4 wires connected to the L28ET C.A.S., one is Battery Voltage, one is Ground, one is the 60 degree slit signal back to the ECU, and one is the 1 degree slit signal back to the ECU. It's easiest to refer to the wiring at the CAS connector: Red = Battery Voltage, Black = GND, Green and White are the two "degree" signals back to the ECU (but I always get them mixed up). With the rectangular 4-spade connector pulled from the distributor, make sure you have voltage and ground with the ignition on. You can also check continuity of the green and white signal wires back to the ECU pins. Then plug the connector back in. You can find how to test the CAS in the 1990-1992 Infiniti M30 Factory Service Manual (probably also the Z32, Nissan Maxima - any of the VG30E distributor type engines...) Get the FSM from Nicoclub.com. They use the same type of optical module that the L28ET uses, and they describe how to test the CAS in their FSM (at least the M30 FSM does). Basically you remove the distributor (with the harness wiring still attached) and rotate it slowly by hand with the ignition on. You'll monitor the output of the green and white wires one at a time with your electrical meter. It's pretty easy to see the six "60 degree" signals turning by hand - a little more difficult to see the "1 degree" signals. The meter should jump to +5V momentarily as the CAS sends the pulse to the ECU.
- 4 replies
- Electrical
- Missfire
(and 3 more)
Tagged with:
Mine was from a 1999 Kia Sportage. I'm not sure about the year range otherwise. At the yard, I think every Kia blower of that era (late '90's, early 2000's) looked the same - no matter the model. I chose the one from the Sportage because it had the most cabin space... There are a couple of install threads with good pictures of the Kia blower. You might search for those and check them out. I didn't have the foresight to take pics of mine and my install.
Here's my original post - just after I found the Kia blower. I didn't realize it was so long ago. Still blowing strong though... http://forums.hybridz.org/topic/100692-280z-blower-motor-upgrade/?hl=sportage&do=findComment&comment=944052
It's on the right side of the throttle body (inboard). It comes up thru the body and serves as a "stop" to a little flange on the throttle linkage. There's a screw with a lock nut under there. Hard to get to as it's all "upside down". Not your problem, but everything you learn about your engine is a good thing... Your problem is still likely electrical. Wiring and connectors. Don't forget the problem I had with random shutoffs years back: Broken solder joint on the C.A.S. connector spades. May or may not be an issue, something to check if all else proves good. (Made the ECU lose the CAS signal and shut down - problem was fairly random but heat seemed to affect it as well...) You'd need a "new" optical module to check that out unless you can do board level repairs on the optical module circuit board... Get one from a 90's distributor type VG30E - Maxima, M30, Z31. You don't need the whole distributor, just the black optical module (CAS). Are you using the Air Control Valve (Air Regulator '82 280ZX FSM - EF&EC-page 55)? Have you verified that it works (test listed in the FSM)? It should get battery voltage at IGN ON continuously until IGN OFF. There's a bi-metal in there that opens and closes a shutter. It's a very simple part, but the shutter needs to open and close smoothly. You can pull the air hose from one side, turn the ignition to ON and watch the thing slowly open - it should take a couple of minutes. Fully described in the FSM (which is much better than my memory).
My car has factory A/C. I'm pretty sure everyone in this thread does as well. I guess I don't understand the rest of your question... The Kia blower is essentially the same as the stock blower. It has a slightly larger squirrel cage with more vanes and moves more air
Is the driver's and passenger seat interchangeable?
cgsheen replied to dpuma8's topic in S30 Series - 240z, 260z, 280z
You can, but then the recliner is on the wrong side of the seat. If that's a non-issue for you, try it. I've never done it that way... While I say "It's a bigger job that you think", the whole seat can be completely disassembled in 10 minutes or less, seats and bottoms swapped, and reassembled in another 10. It'll take you longer to get the 4 nuts off an early (240Z, early 260Z) to get the seat out of the car than to disassemble the seat itself. You guys with lates don't know how easy you have it... -
Lost 280z found hiding at bottom of lake since 1990
cgsheen replied to 720fast's topic in Non Tech Board
Ooooh, I want that dash! -
Can you reuse origional evaporator with R134A system?
cgsheen replied to josephdaniel's topic in Miscellaneous Tech
Not a stock evaporator core... Glad it came out though and that you got a picture of it. We would all be telling you the wrong thing concerning this particular evap core - stock evap core is entirely different. -
The seat back and the seat bottom are identical. The sliders, rails, and side brackets (recliners - hold the seat bottom and back together...) are not - they are right/left side specific. To swap - disassemble the seats, swap seat bottoms and seat backs, reinstall. Ya, it's a bigger job than you think... -
About time for another BUMP! We don't ship many of these out of the country. We've shipped a few sets to our Canadian brothers, but we just sent a set to a super nice guy with a really nice Z in Saudi Arabia! If you're anywhere near Saihat, look for Mohammed's 240Z! He has them in hand and I can't wait to see pics of his car once he gets these installed...
- 51 replies
You don't need to pull the dash to remove the blower box.
Have you unbolted your fuse block and looked at the back side? The B/W from the IGN switch feeds two fuses (3rd and 4th from the top, left side). 3rd: Marked "F" - Green wire out to: Voltage Regulator, Water Temp Relay (except CA), "Check" Connector, A/T something, Catalyzer Hold Relay (CA), Bunch of Cat related stuff for CA models. 4th: Marked "Int" (?) - Blue wire out to: Hazard switch, Fuel Warning lamp, Ignition Interlock, Coolant Temp & Oil Pressure Gauge, Auto Trans Kickdown Switch, Interlock Relay. So... You need Battery Voltage on the B/W that feeds the fuse block. Check the back for heat / melting. Trace the B/W back to the IGN Switch to see why there's no voltage. Check and make sure it's not melted down in the dash harness. I'd want to know why there's no voltage at the fuse block. (The B/W will branch off various ways - From the IGN Switch it also runs over to the passenger side through the dash, goes up the passenger fender well, across the radiator core support, to the coil location...)
- 5 replies
- 280z
- alternator
(and 4 more)
Tagged with:
No. The 280ZX blower (and all other Nissans from then on) spin the opposite direction. The blower box is different due to the rotation. Nearly every other model import also. That was my conundrum while I was grazing thru the Pick-A-Part... The only blowers I found that were similar size and set up to spin the same direction as an early Z were the Honda Civic and the Kia...
I don't think so (at least not this easily), but I'd have to look at the circuit diagram for the Z32. They introduced a "safety circuit" and re-designed the fuel pump circuit at some point. With the Infiniti M30 ECU as an example, you have to rewire the entire circuit back to the fuel pump...
After the first swap we did, we started just using the ZXT fuel pump relay. It's actually a very simple circuit and then you just need to find the green wire to the fuel pump in the passenger footwell. You simply tie the "output" of the fuel pump relay to the Green (fuel pump voltage) wire in that harness on the passenger floor that runs to the rear of the S30. If you don't have the ZXT relay you can wire another standard relay in it's place. The circuit diagram describes this very well and it's simple to do. As easy as this is, DON'T wire the fuel pump "hot" - let the ECU control the fuel pump like it's supposed to. Much safer that way.
I'll want a set of two-piece door panels as well. If you build them, I'm assuming we're using our own uppers and covering them as we please.
Tempe Sales on Broadway west of Mill. Space Age Paint on Country Club in Mesa (South of Broadway)
